TRANNY CONFUSED?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 32 (permalink) Old 09-18-2012, 09:26 PM Thread Starter
97blackbetty's Avatar
TRANNY CONFUSED??
bought a 97 powerstroke about a month ago..guy who owned before me had the edge evolution chip installed and i think he messed with the shift points cuz the tranny seems to not know when to shift or how to stay in just one gear.
i unplugged the chip but and the problem went away...temporarily. noW it does the same crap but with no chip..
WTF HAPPENED?!
97blackbetty is offline
post #2 of 32 (permalink) Old 09-18-2012, 09:49 PM
ToMang07's Avatar
Re: TRANNY CONFUSED??
Was the evolution a flash tuner?
Is the O/D light blinking?
~Tom~ 02 F350 CCSB 4x4 SRW 7.3L, DIY-6637, PHP Phoenix-(STK-80dd-100P-120R-65T-40T) 4" TB-409SS MBRP, GS 3 in 1, EGT/Boost/Tranny, Fisher 8' MM2. Tymar HPX, NON-EBV Pedestal, Turbo Master, Wicked Wheel, Hutch/Harpoon, RR-Plenums/clamps, 203*TS and Billet Housing, ELC, Fumoto, CCV Dumped, Foil, AIH, and EBV, Pontoons All Missing...~AE w/Ford Pack~
ToMang07 is offline
post #3 of 32 (permalink) Old 09-19-2012, 02:59 AM Thread Starter
no the chip was not a flash tuner which is why im not a fan..and no the only light to come on is the ABS light which im not sure if they issues are connected..
after some more symptoms today i might have come to the conlusion that my automatic clutches are slipping? i cant quite figure it out!
post #4 of 32 (permalink) Old 09-19-2012, 03:31 AM
josh77's Avatar
abs light on the abs uses the same sensor for wheel speed as the comp/speedo that may cause shifting priblems. Does ur speedo bounce around?
97ccsb 4x4
395k miles
3"dp 4" exhaust
digital egt gage & trans temp
aeroforce intercptor single gauge
swamps ts chip
baby swamps
kc turbos billet wheel and 1.0 housing
dana 60 swap (all stock 350 stuff for now)
77 f150 4x4 rclb
getting a 4.6 4v with m5od soon (in process)
josh77 is offline
post #5 of 32 (permalink) Old 09-19-2012, 04:52 AM Thread Starter
yes my speedometor is like on meth!! iv been having trouble finding where that connection is tho all my wire connectios underneath the truck seem tight
post #6 of 32 (permalink) Old 09-19-2012, 05:35 AM
ToMang07's Avatar
IIRC it's the sensor on the top of the tranny, VSS???
ToMang07 is offline
post #7 of 32 (permalink) Old 09-19-2012, 05:40 AM Thread Starter
VSS?? but ok thanks ill look tomorrow and try to find it i really hope that will be the fix!!
post #8 of 32 (permalink) Old 09-19-2012, 05:46 AM
ToMang07's Avatar
It might be on the rear differential, now that I think about it.
Have you scanned your truck yet? O/D light flashing?
ToMang07 is offline
post #9 of 32 (permalink) Old 09-19-2012, 06:38 AM
Davey B
davey99ps's Avatar
Check your tail lights an 3rd brake light, on the obs it can cause shifting issues
95 CCLB- 238/100s, H2E, termy t500, wipe out pushrods, comp 910s, mbrp exhaust, bdp tunes, and 8" lift
99 ex cab - Rolled 3/10/10
davey99ps is offline
post #10 of 32 (permalink) Old 09-19-2012, 02:13 PM Thread Starter
I won't have time to get it scanned till Friday but I have noticed the OD light flash a couple times.. But it's random seems like
