truck start up with miss - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 09-07-2007, 09:10 PM Thread Starter
Taters #2 Fan
JohnDeere9610's Avatar
Send a message via AIM to JohnDeere9610 Send a message via Yahoo to JohnDeere9610
when I start my truck first start of the day. It blow white smoke and has a miss untill it warmes up abit. drive down the road 1/4 mile. Its still summer here so I dont let the glow plugs burn all that long. But I wouldnt think it should smoke as much as it does.
Injecters need to be reworked?
Its been doing this for awhile just figgured I would ask away. Kinda bored
RDRCM# Five O
95 F350
Full Force stage 3 Hybrids
H2E
2L Motorsports Gen 3
Beans fuel system
Transmission by Jon Faubion
Tuned by the "WILDMAN"
99.5 Dodge
P-Pump 24v
2.6 puller
"Whitey"
JohnDeere9610 is offline
post #2 of 10 (permalink) Old 09-07-2007, 11:41 PM
Re: truck start up with miss
Could be a bad glow plug or two or a bad injector. With it still being fairly warm out I'd lean toward and injector. Do a cylender contribution test on it and see what it says.
hotwheels is offline
post #3 of 10 (permalink) Old 09-09-2007, 02:29 AM
<----Colin Banks
mattymx's Avatar
That is a glow plug issue and the white smoke is unburned fuel. You either need to install new plugs, or new GPR, or new batteries, or new cables.
When my 96 did this, I installed new glow plugs and that did not fix it. I installed new batteries and that was not it. I was informed by someone it might be the cables. Cables looked good but that was the problem. It lights right up now even when it was below 0 this last winter.
mattymx is offline
post #4 of 10 (permalink) Old 10-03-2007, 07:50 PM
Jeepermc's Avatar
I too have a rough runner first 5 or 10 minutes with some white smoke on startup....Glow plugs and relay are new. It started when I swapped injectors. I think it's an injector problem.
1997 F-350 PSD. Std Cab. Auto. IDM Mod, 1's,17* HPOP, TS-6 pos. tweaked by TW. ARB Bull bar, 8,000# Warn, IPF lights, 315/75/16 Toyo mud terrain.
Jeepermc is offline
post #5 of 10 (permalink) Old 10-04-2007, 12:56 AM
X Racer
Racer X's Avatar
Mine started that after adding an intake and losing a cat. White smoke at start up is cold combustion temps. Brand new Cat engines blow smoke too
Contact Racer X USA for Fully Custom built transmissions, Torque Converters & Valve Bodies.
Racer X is offline
post #6 of 10 (permalink) Old 10-04-2007, 01:13 AM
<-Friends bike
Mine quit after the IPR crapped out & replaced it with new.....
Most of the time you could still see the truck...(its white).......
ActionRick is offline
post #7 of 10 (permalink) Old 10-04-2007, 06:28 PM
All Ford Guy
White smoke is kind of the classic g/p system indication. That is also easier to check out than injector issues, so it makes sense to start there... ohm them out and confirm the relay is giving them power.
If you eliminate the g/p system as the problem, the first injector test would be measuring the clearance under the armature plate (which would reveal worn poppets). The classic symptom for worn poppets is the miss on cold start that goes away like someone "flipped a switch" and it then runs perfect. Also seems to show worse after extended cold soak when the oil is nice and thick.
Oh, does the motor run great when it's warm?
TC
97 F350 CC LB 4x4, ZF-5, LUK, Off-Road. Factory Alcoas, Michelin LTX-M/S LT265/75-16, Bilsteins. Homegrown intake, 4" exhaust, LUK clutch, 130cc injectors, 99+ intercooler, homegrown CCV mod, homegrown electric fuel system, still sorting out tuning/chip burns.
2003 Tahoe 27' Travel Trailer, Prodigy brake controller.
1991 5.0 LX - Best 1/4: [email protected]
1989 Taurus SW (To be like Tom S!)
Link to my Intercooler/Fuel System Install page -
TimC63 is offline
post #8 of 10 (permalink) Old 10-09-2007, 06:52 AM
Do you just have stock ADs? Should try going back to some singles that flow 160cc or so of fuel. I think you will like them a lot better.
post #9 of 10 (permalink) Old 11-21-2007, 10:05 PM
Jeepermc's Avatar
In good time I will....
Jeepermc is offline
post #10 of 10 (permalink) Old 11-22-2007, 03:43 AM
OBS junkie
Cat_Rebel's Avatar
I'd say Glow Plugs or injectors.
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
Cat_Rebel is offline
