Grease coming out of right front hub - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 11-28-2011, 05:54 PM Thread Starter
We finally got some rain the other day here in central Texas and I had to use my 4x4. I then drove 3 hours home from my ranch and when I got home, I noticed some grease had come out of the right hub (auto locking dana 50 in f-250). It didn't look like much had come out, and I never heard any noise coming from the hub. I took off the little cover with the three torx bolts holding it on and didn't notice any metal shavings or any grease seeping there (the grease had come from under that cover.) It also doesn't seem to be leaking any more grease from there. I don't think all the grease came out, because there are just a few specks on the wheel/tire.
Am I about to lose a hub? Do I just need to repack the bearings? If so, how do I do that?
97 F-250 ECLB ZF5 7.3 4x4, 6637 Filter, MBRP 3" to 4" with 5" tip, HPO xover pipe, shimmed FPR, Boost and Pyro Gauges, PHP chip with stock, 60 hp, 80 hp, 140 hp, high idle, and no start
iluv83vettes is offline
post #2 of 3 (permalink) Old 11-29-2011, 06:15 PM
Re: Grease coming out of right front hub
Jack up the side you're talking about. Grab the top and bottom of the tire. Attempt to wiggle the tire in/out. If there is play, it'd be worth it to tighten the bearings up.
The grease could have worked out because some water could have gotten into the hub.
96 CCLB XLT, Napa BHAF, TS 6pos, glow shift guages (pyro boost trans), 3" downpipe, 4" pipes. 6lift, 325/85 XML.
84 K5 - LQ9 swap (6.0) 4 speed detroits, 38's...
I'm a Newb ....and I accept it.
K5383 is offline
post #3 of 3 (permalink) Old 11-30-2011, 01:26 PM
96P_Stroke4x4's Avatar
the large oring between the cap and hub could also be flattened and may need to be replaced. my truck is doing the same thing and i will change those orings soon.
'96 F-250 XLT,x-cab,4x4,BTS,363k,dana60,Swamps175/173s,Dieselsite Adrenaline HPOP,CPR Fuel system,rear discs,4" dp to 6" exhaust,twin 6" stacks,Tymar, Boost Pyro Tranny and white-faced gauges,I/C,onboard air,HX mod,TW 6-position chip
96P_Stroke4x4 is offline
