should i replace injector o-rings when changing injectors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 11-28-2011, 01:34 AM Thread Starter
winkfab's Avatar
I pulled the injectors out of one truck (150,000 miles)and want to put them in my other truck. The truck ran fine before I pulled them out, but when I looked at the injector and the cups, there are stains on the bottom edges of them like oil or something. Should I put new orings on them or is this common?
Wink Fab - cnc machining and fabrication
2008 f250 4x4 bone stock and ready to mod/repair
97 f350 4x4 410 gears 37 BFG, 4" exhaust, dyi, tw chip,
IDM mod, .427 sonnex valve, rsk w/sd springs, grease able 4x4 lever,Rosewood stage 2, T-500 hpop,1.0 ex housing
These trucks are like crack, you just can't leave it alone.
winkfab is offline
post #2 of 4 (permalink) Old 11-28-2011, 01:39 AM
I like turtles
NE-STROKE's Avatar
Re: should i replace injector o-rings when changing injectors
I would definitely do the o rings. The oil stains are common.
08 duramax ccsb efi live, air dog 2, isspros, 5 inch exhaust and some other cool things. 2001 duramax 2wd (Project truck)
Once had a signature that had some bad ass stuff on it. Now its back to crap.
NE-STROKE is offline
post #3 of 4 (permalink) Old 11-28-2011, 03:06 AM
Edward Scissorhand WanaB
Bushwakd's Avatar
You will need to replace the exterior O rings as well as the copper crush washer located at the injector nozzle base. You can get them at your local dealership or international dealer or http://shop.fullforcediesel.com/Injector-Orings_c3.htm or http://www.dieselorings.com/index.ph...cat=23&group=6
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #4 of 4 (permalink) Old 11-28-2011, 02:46 PM
goto International for your injector o-rings...Ford hits you for displaying their logo on the package
'95 F250 SC 7.3 auto 4x4 long box...Rosewood stage 1's tymar intake 3"DP...Dfuser AIC... 263,000 and runnin' strong!!
mojoman is offline
