S/D injectors in my obs - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 11-27-2011, 03:09 PM Thread Starter
DD95's Avatar
I have a set of superduty injectors with only 10k on them and was wondering if these would work with my idm /pcm. I have already installed the s/d 17* hoop and plan on installing a Turbo I have from a 02 E350 van.
DD95 is offline
post #2 of 7 (permalink) Old 11-27-2011, 04:07 PM
Re: S/D injectors in my obs
Yep, but split shots arent that great. That's why you see people pull the SD splits in favor for either some stage 1's or bigger single shot injector.
02 f250
countryboyrob is offline
post #3 of 7 (permalink) Old 11-27-2011, 04:12 PM
95powersmoker's Avatar
They will run but it might not be as smooth as you like. I would get some tunes to run the splits properly. I ran splits in my truck with tunes for them and still wasn't happy with them, pulled them and have been running my 1's for a year now..
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #4 of 7 (permalink) Old 11-29-2011, 02:32 PM Thread Starter
DD95's Avatar
I have an edge evolution in the truck now. But I like the idea of stage 1's but they are pretty costly for a blue collar pay check. Can I just replace the nozzles on my stockers kinda like the DIY kits you used to be able to buy. Or dose anybody know of any good used ones I can pick up for a good price.
DD95 is offline
post #5 of 7 (permalink) Old 11-29-2011, 02:43 PM
Cratos's Avatar
if you get a chip tuned for them you will be better off.to get full use you will want to upgrade you fuel system or your FP will be falling off @wot
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #6 of 7 (permalink) Old 11-29-2011, 03:31 PM
Putting nozzles on a 90cc injector would make less sense to your blue collar paycheck... Check with Rosewood for some of his budget minded injectors... Diesel Performance is a pay to play game, if you have to save up a little, do it so you can build up the right way.
James
post #7 of 7 (permalink) Old 11-29-2011, 06:36 PM
Fixing Broken Stuff
toolmangary's Avatar
Would SD injectors work in OBS with a stock SD PCM???
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
