Center console cup holder - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 11-24-2011, 07:06 PM Thread Starter
So one of my kids put a couple quarters on the sliding cup holder cover and then opened it. Now the quarters are inside :) I want a coffee and my money is inside the "truck vault", now how do I remove the plastic cup holder/ storage and get the money out of there so I can use my cup holder again?
Got4wd is offline
post #2 of 10 (permalink) Old 11-24-2011, 07:48 PM
Re: Center console cup holder
Good luck.......I broke mine trying to open it up
02 f250
countryboyrob is offline
post #3 of 10 (permalink) Old 11-24-2011, 08:38 PM
krisx125's Avatar
I spilled a Large ice coffee...and 99% of it went inside the storage thingy...Yea its bad..does that come apart for cleaning? lol
Kris
1997 F250 7.3 5speed, Valiar clutch, guages Boost, Water temp, EGT, 130k miles, 3" DP, 6637 filter.
2007 F350 King Ranch, All STOCK 25k miles.
2002 F-450 zf-6 4X4 Flat bed 60k
1983 F250 5.8L plow truck
krisx125 is offline
post #4 of 10 (permalink) Old 11-25-2011, 04:29 PM
Patrick Feeley's Avatar
There are a bunch of tabs that hold the bezel/cover on the seat back. Usually you end up breaking most of them off trying to get it off. Good Luck & Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #5 of 10 (permalink) Old 11-25-2011, 07:17 PM Thread Starter
When you say "seat back" do you mean where the cup holder is?
Got4wd is offline
post #6 of 10 (permalink) Old 11-25-2011, 09:48 PM
ate lug
reptillikus's Avatar
I have the 40/20 split bench as well. I pulled the cover off mine in order to rescue some lost change, and to clean it. To put it back together, i replaced the 2 rubber pieces with small screws. I realize this pic sucks, but it should give you a good idea of what i did, as it holds everything together nice & tight. Its just two regular stainless flathead screws in place of the rubber bumpers that are supposed to keep the cover in place.
reptillikus is offline
post #7 of 10 (permalink) Old 11-25-2011, 10:41 PM Thread Starter
So that whole piece pulls off? What do the rubber piece do?
Got4wd is offline
post #8 of 10 (permalink) Old 11-26-2011, 01:29 PM
Moderator
PsRumors's Avatar
I believe i have read there is a specially made specific tool for doing this job.
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #9 of 10 (permalink) Old 11-26-2011, 03:22 PM
weareweird69's Avatar
True.
Take it to a well known upholstery shop and have them remove it for you. Tell them to be very careful with it because that peice, IF you can still get it, is over 100 bucks.
weareweird69 is offline
post #10 of 10 (permalink) Old 11-27-2011, 12:37 AM
ate lug
Mine were already broken, so the cover flopped around a bit. I just removed them, and replaced them with thhose small screws. I dont know what retains it in the back, but with those out you can lift the cover up a couple inches; more than enough to get whatever was lost.
