Died immediately on start up. Now no start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 11-24-2011, 04:30 PM Thread Starter
Addicted Offroad
AddictedOffroad's Avatar
Wow, its been a hell of a week with this truck.
This morning I was planning on heading to my shop to swap out the fuel pump. Its starting to weep and I wanted to get an early start so I wouldn't miss Thanksgiving with my family. And, I was planning on towing my buggy to Penrose tomorrow to go wheeling.
Truck started normally this morning. It was about 25 degrees out. It wasn't plugged in. "wait to start" light came on, and it fired right up. Everything seemed fine. Then 10 seconds into running it died. Tried to restart and wasn't getting a "wait to start" light or any others on that panel. Found three blown fuses under the hood. #22 as expected, but also #1 and #7(mini bus fuse). Replaced them all and verified all fuses are now good under the hood and in the cab. Pulled codes through my Scan Gauge II and literally have nothing. No codes.
In fact, I don't even see a spot in the dash where the "CEL" would even light up. There is nothing and I have never even seen one. Build date of this truck is 02/96.
I did pull the fuel bowl yesterday and replaced all of the fuel lines on it trying to track down what ended up being the fuel pump weep. But, I drove it home from the shop last night with no issues.
Beginning to think its a PCM issue. Any ideas?
AddictedOffroad is offline
post #2 of 12 (permalink) Old 11-24-2011, 08:40 PM
Running at last...
powerstroke cowboy's Avatar
Re: Died immediately on start up. Now no start
does it cranck over????
97 CCLB 4x4 ZF6 [email protected]
powerstroke cowboy is offline
post #3 of 12 (permalink) Old 11-25-2011, 12:32 AM
Unplug the fuel bowl heater, replace fuse #22 again
loudmouth is offline
post #4 of 12 (permalink) Old 11-25-2011, 06:29 AM
theoldgirl1990's Avatar
I had the same sort of problem last week. I would get a crank, but no fire. I found out I was not making enough high pressure oil to fire the injectors. I replaced my ipr and all was well. Get a scan tool to read pressures and see where you are at.
1996 F-350 cclb, H2E, e-fuel, srp1.1, custom tuning, banks intercooler, 3 in plenums, swamps babies, ARP's, comp 910's, Isspro EV2's, rsk v/c codes, 5 inch exhaust, king ranch seats, SD 10.5 axle, swamps idm, 6.0 fan, international w/p, hydroboost, SD trans lines, 6.0 trans cooler,6.0 P.S. pump
theoldgirl1990 is offline
post #5 of 12 (permalink) Old 11-25-2011, 06:34 AM
your mom
RMPowerstroke's Avatar
Sounds like a hpo problem. If it starts good all the time when cold but once warm dosent start look into hpo .
f350 king ranch dubed. ol ranchero thanks to wayne
04 cc/lb 9inch lift C-6 built converter custom revs manual valve body r servo. powered by 12v cummins p-pump 4k gvs custom lasered dlv pump work, 5x16 sticks, singler charger for now, airdog150, its on meth lots of custom junk. hids road armor bumper and im truck broke
06 f-150
RMPowerstroke is offline
post #6 of 12 (permalink) Old 11-25-2011, 09:10 AM
needs more fuel
96f350psd's Avatar
i agree, unplug fuel bowl heater, replace #22 and try again. before i found this site (years ago with my first psd) i blew 5 of these dern fuses trying to figure out what the problem was. unpluged the fuel bowl heater and replaced with a new fuse and it fired right up. it would blow the fuse as soon as i turned the key on.
-Mason
96 f250 xl reg cab lwb 7.3 zf-5 3.5" straight pipe with
87 f150 xlt 302 original aod 3:55s straight pipes
90 bronco 6" lift 35s 302 aod, locked rear end
89 f150 302 aod 4x4 15x8 mb razors 33" swampers
And like paul said, a smoke tune on 90cc injectors is about as useful as dial up internet when trying to watch porn.
96f350psd is offline
post #7 of 12 (permalink) Old 11-25-2011, 01:16 PM Thread Starter
Addicted Offroad
Update, it was the heating element in the bowl.
So, the question i have is, I live in Colorado. We will get several days under 0* out here in the winter. How critical is the heating element? I searched and found a few people not running them, but just want to know. Will I be good with some fuel additive/anti-gel alone and keeping the engine block heater plugged in on those days?
post #8 of 12 (permalink) Old 11-25-2011, 03:13 PM
mandkole's Avatar
your good without it-- if it gets real cold, just plug in the block heater.
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
post #9 of 12 (permalink) Old 11-25-2011, 03:35 PM
Running at last...
We get -45F at times without the wind chill. And Without the fuel heater it made no differance. Just keep good additave in there like Howe's diesel treat. With Howe's diesel treat I have NEVER had a jelling problem even when all the other diesels we had on the place jelled..
post #10 of 12 (permalink) Old 11-25-2011, 09:02 PM
tony3542's Avatar
Where is this plugs exact location?I've had this happen a time or two.
Thanks,
Tony
tony3542 is offline
