95 7.3 hpop draining overnite issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 11-22-2011, 02:42 PM Thread Starter
Boost96's Avatar
A guy I know is having this issue, it drains after sitting overnite..causing starting problems
. Is this the front cover drain back issue?, I've seen the write-up. He has a new hoop and new ipr also. What else could be causing this?
Boost96 is offline
post #2 of 3 (permalink) Old 11-22-2011, 08:09 PM
Patrick Feeley's Avatar
Re: 95 7.3 hpop draining overnite issue
Was the replacement HPOP the same as his old one or was it a newer one? The later HPOP on an an earlier front cover will have drainback issues. Cheers!
Patrick Feeley is offline
post #3 of 3 (permalink) Old 11-23-2011, 03:57 PM Thread Starter
Boost96's Avatar
I'll ask him, so its possible that his new HPOP is a stock replacement for a 95 causing the problem, I wouldn't be surprised if his mechanic did this. I told him to get a adrenaline or a SD pump
Boost96 is offline
