ebpv closing too much - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 22 (permalink) Old 11-21-2011, 11:40 PM Thread Starter
deezeljunky's Avatar
Question ebpv closing too much
Hey guys I just recently got a 1997 psd zf5 crew cab with 290,000 on the odometer. The problem is that in the morning the ebpv closes like it should but it almost seems like it closes up too much because it has absolutly no power and stuggles to get up to speed. The valve stays closed until the temp guage needle hits the "N" on normal and the engine is idling. I felt this was odd because on my other obs the temp never goes above 1/4 of the guage face, and the ebpv dosnt effect the engine barely at all if any. Now the truck that has the problem is bone stock except for a k&n intake (soon to be changed) and a new fuel pump, intake pressure sensor. And my other obs i am reffering is straight piped, has 6637 filter, a ts chip, and is an auto. Im not sure what to think at this point, ive heard you can unplug it but i cant find the plug for it, im thinking about gutting to elminating the problem altogether. Thanks ahead of time.
deezeljunky is offline
post #2 of 22 (permalink) Old 11-21-2011, 11:56 PM
Re: ebpv closing too much
sounds like it sticking?
corybens11 is offline
post #3 of 22 (permalink) Old 11-22-2011, 02:47 AM
powerstroker66's Avatar
the sensor gets gummed up with exhaust soot. Just unplug it, Take the "7.3 powerstroke cover" off and its right near the glow plug relay plate. It sticks stright up and you see the metal tube coming into it from the exhaust manifold.
powerstroker66 is offline
post #4 of 22 (permalink) Old 11-22-2011, 03:44 AM
Patrick Feeley's Avatar
Remove the tube between the passenger side exhaust manifold and the EBP sensor and clean it out (it removes and snakes out fairly easily from under the alternator). I like to use carb cleaner and some wire rope chucked it a variable speed drill (just like a plumbing snake). Also clean the little bit left at the sensor and the sensor. The plug for the EBPV solenoid is at the base of the turbo on the driver's side (teo-wire weatherpack connector). Cheers!
Patrick Feeley is offline
post #5 of 22 (permalink) Old 11-29-2011, 03:35 AM Thread Starter
I tried all of this and it still does the same thing. Should I just buy a new sensor?
post #6 of 22 (permalink) Old 11-29-2011, 03:04 PM
the senosrs are roghly $80 if you buy international, i personally think its not worth it. Have you tried unpluging it to see if that is the problem? You shouldnt need the EBPV if you let your truck warm up i ran mine all last winter with it unplugged i just made sure i eaither plugged it in or gave it a good warm up time.
post #7 of 22 (permalink) Old 11-29-2011, 05:54 PM Thread Starter
I unplugged the sensor, the two prong connector, and both at the same time and it still does the same thing. I must not be unplugging the right one, but its the only two prong connection right under the turbo. This thing is starting to drive me crazy!
post #8 of 22 (permalink) Old 11-29-2011, 06:17 PM
if you unplug the actuator plug then yes it will stay shut because it cant move. If you unplug the pressure sensor near the GP relay it should tell the EBPV actuator to stay open.
post #9 of 22 (permalink) Old 11-29-2011, 10:33 PM Thread Starter
I tried unplugging both seperately, and both at the same time, and it still does the same thing.
post #10 of 22 (permalink) Old 11-30-2011, 03:45 AM
mandkole's Avatar
underneath the intake side of the turbo is the plug for the valve itself-- just unplug it and it will stay open all the time.
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
