Question about Fuel Filter Restriction Switch... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 11-21-2011, 11:18 PM Thread Starter
CumminsTrader's Avatar
Hey,
I went home this Sunday to move the truck and trailer to their "winter homes" i.e. inside the truck shed as it had been sitting outside for a few weeks waiting to move some equipment around. Been pretty cold out last week or so and the truck wouldn't start. Didn't have winter blend or #1 in it when left it so I figured it may have gelled up. Towed it into the heated shop and left it for a while so I could go move the trailer into the shed and had a battery charger on it. Long story short, did some quick TS when it still wouldn't start foundthe fuel filter to be pretty dirty. Now the last few trips with it I had noticed power seemed to be down and so was fuel economy, but the fuel filter restriction light has never come on. I thought it may be the fuel filter, but was getting ready to install my new fuel system with filters and didn't want to "waste' money on another stock replacement filter.
So my question is, does anyone know what pressure or vacuum the Fuel restriction switch trips? I know it must be a normally closed switch, but is it held open with pressure (i.e. when the pressure drops below "X" it closes) or is it pulled closed with vacuum? Seeing it's position on the bowl, I am inclined to think it is a minimum pressure holding it open. I am intergrating it into my new fuel system and would like to know if anyone knows this info. I am not ready to remove it or I would test it myself.
Switch could be bad I guess.....
Cory
1995 F350 CC DRW XLT 2WD 5-Spd w/ BD Exhaust Brake 225K Mi, HyperMax Stage 2 Kit, HyperMax EGT & Boost Gauges, Riffraff / Tymar Intake, HyperMax Intercooler, HyperMax 330HP chip, Adrealine HPOP & Braided Lines, Melling M208 LPOP and HyperMax 4" Exhaust. Coming Soon: DP-Tuner F-6 and custom electric fuel system.
CumminsTrader is offline
post #2 of 12 (permalink) Old 11-22-2011, 03:40 AM
Patrick Feeley's Avatar
Re: Question about Fuel Filter Restriction Switch...
I don't know if I've ever heard of one being bad, other than leaking fuel like a sieve. I don't recall ever seeing a spec on the switch, but it is a vacuum switch. Cheers!
Patrick Feeley is offline
post #3 of 12 (permalink) Old 11-22-2011, 10:44 PM
One Stroke @ a Time
jsnyder7.3's Avatar
Hate to start a debate, but its a fuel operated pressure switch not a vacuum switch. It is on the low pressure side of the bowl assembly which means its only reading at max 7-8 psi. You can also interchange the switch off of an IDI as its the same readings. I believe it comes on below 5psi, but I won't swear to it. I have an old switch I will see if I can reverse my vacuum diaphragm set up to reg pressure and get you an accurate reading. Good luck.
97 F350 CCLB 4x4
a bunch of costly things and some bloody knuckles, but a lot of fun to drive!
"Loaded like a freight car, driven like a stock car!"
jsnyder7.3 is offline
post #4 of 12 (permalink) Old 11-23-2011, 03:54 AM
That doesn't really make sense to me. I know the switch closes with a plugged filter. If it closed simply on low pressure (say below 5 psi), why wouldn't it come on with a bad fuel pump? Cheers!
post #5 of 12 (permalink) Old 11-23-2011, 01:10 PM
One Stroke @ a Time
jsnyder7.3's Avatar
The switch is a N/C (normally closed)ground switch. With the truck running the fuel pressure opens the contacts of the switch removing the ground and turning off the light on your dash. Also why you can unplug it and the light doesn't come on. The main reason that the light doesn't normally come on when a fuel pump goes out is that its a 2 stage pump. The restriction sensor is on the low pressure side or lift side of the pump. Once the fuel goes through the filter on the low pressure side it goes back into the high pressure side of the pump (remember 2 stages) and from their through the heads and injectors and back to the regulator and return on the side of the fuel bowl. The switch is not in the high pressure side of the pump which is normally the side that will fail on these trucks. I hope that makes sense.
97 F350 CCLB 4x4
post #6 of 12 (permalink) Old 11-23-2011, 03:23 PM
Hmmm, the EVTM states that the switch closes with plugged fuel filter. Cheers!
post #7 of 12 (permalink) Old 11-23-2011, 04:08 PM Thread Starter
The point is that it is held open by a minimum pressure thus no light. If the filter becomes restricted, the pressure drops due to the pump not being able to pull fuel through the restriction, thus allowing the switch to return to its normally closed position and grounding the negative side of the circuit causing the light to come on. Since the low stage of the pump is only about 6 PS I, I would imagine it is around <5psi. Remember negative pressure = vacuum. Thanks for the replys.
Cory
post #8 of 12 (permalink) Old 11-23-2011, 08:14 PM
One Stroke @ a Time
jsnyder7.3's Avatar
Thanks Cory. But just to clarify the switch is on the pressure side not a vacuum side of the pump. Looking from the front of the engine the top right port of the pump is vacuum side directly from the tank. The top left is low pressure through the filter, it returns from the filter to the bottom side of the pump through the second stage and high pressure out the back to the back of the heads, then out of the front of the heads to the braided lines to the regulator on the side of the fuel bowl and back to the tank. So it truly is a pressure switch not a vacuum switch.
97 F350 CCLB 4x4
post #9 of 12 (permalink) Old 11-23-2011, 10:25 PM Thread Starter
I know I agree it would be located on the pressure side of the first stage (diapraghm lift section) where fuel pressure is approx 6psi. If the filter becomes plugged, the fuel flow is reduced, which I turn reduces the pressure across this stage and the second stage. I would imagine if the first stage of the pump became weak enough or failed, you could get this light for that as well since it is simply a pressure switch.
On a side note, I realize I miss typed on my earlier post today. I believe this switch grounds an input to the ECM which commands it to power the restriction light. This is why those indicator lights go through a test flash at startup. I will have to confirm with a wiring diagram, but I doubt this switch directly applies power or ground to the indicator light.
Cory
post #10 of 12 (permalink) Old 11-24-2011, 02:39 PM
One Stroke @ a Time
jsnyder7.3's Avatar
You are correct it does go through the main harness.
97 F350 CCLB 4x4
