97 Steering Column - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 11-21-2011, 02:21 PM Thread Starter
BROKE as a JOKE
97 Steering Column
Guys, I need to replace the turn signal/wiper/hazard lever and the gear shift lever.
Anybody torn into their steering column before? Any help/advice/tips would be awesome! Thanks!
2015 F-350 CCSB King Ranch
6.7 PowerStroke, 3.55 LS, 4x4
stupid_rope is offline
post #2 of 11 (permalink) Old 11-21-2011, 02:58 PM
ate lug
reptillikus's Avatar
Re: 97 Steering Column
As i recall, its very easy to do once you unbolt/drop the column down off the dash. You shouldnt have to remove the column to do it.
reptillikus is offline
post #3 of 11 (permalink) Old 11-21-2011, 03:43 PM
zilla68's Avatar
all you have to do is remove the cover from behind the steering wheel, takes maybe 20 minutes or so, you do not need to drop the column, hardest part was getting the cover off, rest was easy.
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #4 of 11 (permalink) Old 11-21-2011, 05:20 PM
95powersmoker's Avatar
I think there is like 3 or 4 screws that hold the cover together... You will have to take out the ignition but that isn't too difficult either.
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #5 of 11 (permalink) Old 11-21-2011, 05:48 PM Thread Starter
BROKE as a JOKE
sweeeeet. i'm replacing the ignition switch while im in there, since my past experience has had these go bad in these trucks
post #6 of 11 (permalink) Old 11-22-2011, 10:56 PM
One Stroke @ a Time
jsnyder7.3's Avatar
If you are replacing the actual ignition switch and not the lock cylinder you will have to drop the column as it is mounted on top of the column under the dash. Other than that the multi function switch and the shift lever are very easy! If you're as picky as I am make sure you take the time to re-adjust the shift indicator cable before you put the cover back on, otherwise it maybe off after replacing the handle.
97 F350 CCLB 4x4
a bunch of costly things and some bloody knuckles, but a lot of fun to drive!
"Loaded like a freight car, driven like a stock car!"
jsnyder7.3 is offline
post #7 of 11 (permalink) Old 11-23-2011, 01:01 AM Thread Starter
BROKE as a JOKE
Thanks man, i'm very picky (anal-retentive) especially with my vehicles, so i will make sure i adjust that
post #8 of 11 (permalink) Old 11-28-2011, 05:25 PM Thread Starter
BROKE as a JOKE
New shift lever and multifunction switch went in just fine.
Still have a little bit of slop between N and D...any ideas?
post #9 of 11 (permalink) Old 11-29-2011, 01:44 AM
5 speed swap should fix that slop
jimmyducati is offline
post #10 of 11 (permalink) Old 11-29-2011, 02:03 AM
crazed & deranged farmer
NutFarmer97's Avatar
Mine did more or less the same thing after I fully rebuilt my steering column, Its most likely ware on the shift lever in the cast aluminum tube on the column.
1997 f350 CCLB 4x4 PSD, stage III hybrids 250cc/80%, 38r, SD-IC, NAPA 6637 air filter, Reg-Return AirDog II, TE Moded 17* HPOP, SD 3" intakes & spider, TS chip w/Matt's tunes, & built E4OD. Hydroboost brakes, 350K
1995 f350 cclb xl no frills work truck. Powerstroke 5 speed 4x4 all stock 322K
NutFarmer97 is offline
