Fuel filter housing sensors - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 11-20-2011, 03:30 AM Thread Starter
josh_mangan's Avatar
Quick question, sensor on the lower back of the housing directly above the bottom fuel line and the part #. I finally got around to replace my pump thinking it was the leak well while putting it back together and found the leak....at least I have a new pump on my truck now. Thanks in advance
96' 205xxx completely stock
josh_mangan is offline
post #2 of 4 (permalink) Old 11-20-2011, 03:42 PM
Patrick Feeley's Avatar
Re: Fuel filter housing sensors
On your truck it is the fuel restriction sensor (a known leaker!). It lights up the fuel filter light when the filter is getting restrictive. Part is usually only available from Ford for about $50 and since most folks don't want to get another only to have it leak again, we just plug it with a 1/8 NPT plug (especially in the location on the earlier trucks ... later OBS trucks had it on the FPR block where it is easier to access). Not a big deal if you are good about filter changing. Here's the part number:
Fuel Filter Restriction Sensor
(Ford) E8TZ-9S283-A
Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #3 of 4 (permalink) Old 11-20-2011, 04:41 PM Thread Starter
Thanks for the help. If I plug it will it throw a code?
post #4 of 4 (permalink) Old 11-21-2011, 04:43 AM
Nope. It is only a switch for the filter light on the dash. Cheers!
