Re: "real" oil pressure gauge
The
PCM won't care since it only sees the Engine Oil Temp (
EOT) from the low pressure soil side of things. The gauge/instrument cluster board is the only thing the switch connects to. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
