I need some help! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 11-18-2011, 02:16 AM Thread Starter
I need some help!
I have a 95 f350 diesel. Can anybody tell me why my PCM is turning off and on.
OneHatedOn is offline
post #2 of 10 (permalink) Old 11-18-2011, 03:14 AM
95powersmoker's Avatar
Re: I need some help!
Uh.... I think some more information is appropriate here...
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #3 of 10 (permalink) Old 11-18-2011, 03:17 AM
What do you mean by "turning off and on"?
madpogue is offline
post #4 of 10 (permalink) Old 11-18-2011, 05:21 AM Thread Starter
The truck would idle high and kill. The mechanic had his computer hooked up and he said that the pcm is turning off and on.
post #5 of 10 (permalink) Old 11-18-2011, 05:05 PM
Cratos's Avatar
cps maybe
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #6 of 10 (permalink) Old 11-18-2011, 05:33 PM Thread Starter
I changed the cps,icp,ipr.
post #7 of 10 (permalink) Old 11-18-2011, 08:40 PM
Patrick Feeley's Avatar
It could be many things in wiring that could cause it (first, does it have an aftermarket chip installed?). Best bet is to get a hold of an Electrical and Vacuum Troubleshooting Manual (EVTM ... about $22 at Helm Inc) and start checking all the power feeds to the PCM (wires, fuses, relays, PCM poer diode, etc.). The EVTM makes it a lot easier to visualize what's going on. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #8 of 10 (permalink) Old 11-18-2011, 09:07 PM Thread Starter
Another thing he said that the wts light is flashing and the check engine light comes on and goes off.
post #9 of 10 (permalink) Old 11-19-2011, 01:39 AM
I think I'd be looking for PCM wiring problems if that is the case (just my guess though). Cheers!
post #10 of 10 (permalink) Old 12-15-2011, 07:59 PM
SJD
lifestroker97's Avatar
my truck did that a few months ago... changed the relay for the glow plugs in the fuse panel under the hood and it's been fine since then
lifestroker97 is offline
