Stick to Auto - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 11-17-2011, 08:25 PM Thread Starter
LawnRanger's Avatar
Stick to Auto
I know that most of you are having a melt down just from the title of this thread. That being said, just hear me out.
I've been looking for another RCLB 350 to use as another plow truck and I found one for a good price but it's a stick. I really don't want a stick for plowing, so I was wondering what all would it take to switch it to auto? Would I need to swap steering columns, or could I put a selector on the floor? Like a B&M shifter, and what all else would go into this swap? Any help is appreciated.
'96 F250 XLT CC SB 7.3L 4X4 -
Full Force Stage 1 injectors
3" dp / 4" exhaust w/delete -
TS 6 position chip -
Tymar intake -
Buck Stop front bumper / J&J Ent. Stainless rear bumper -
Air LIft airbags -
D60
4" BDS lift w/35' BFG AT's on 16" ProComp Xtreem Alloys -
'96 F350 RC LB 7.3L 4X4 -
33" MT -
Hiniker 8' C-Plow
LawnRanger is offline
post #2 of 7 (permalink) Old 11-17-2011, 08:45 PM
biggreen96's Avatar
Re: Stick to Auto
If I remember correctly you'll need the auto harness also as its different than the man. Other than tha possibly drivelines
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
biggreen96 is offline
post #3 of 7 (permalink) Old 11-17-2011, 09:08 PM
Re: Stick to Auto
Heh heh I was like WTH LawnRanger what are you thinkin...hahahaa
Having switched the "other" way easiest I think is to get ye self a parts truck configure the same and have at er... or swap with someone who wants a stick...
Iirc the autos are about 6" longer than the ZF so you may need different X member, wiring harness, spacer for auto (2" on end of crank), and possibly drive shafts pending where you are getting parts.
Dash you will need steering column (like the idea of floor shifter and have seen a couple versions somewhere I think on here) so maybe not. Auto peddle box assembly, neutral safety plug, auto PCM. Straight forward swap really perhaps a bit of time messing about getting correct parts if not using a parts/swap truck.
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10s 37Ē Toyo R/Ts intake, FFD 205/30s, DP 4Ē exhaust DIY E-fuel, ZF-5 now
lights: VisionX & HID projectors in headlights.
JCart is offline
post #4 of 7 (permalink) Old 11-17-2011, 09:15 PM Thread Starter
LawnRanger's Avatar
Re: Stick to Auto
jrc
OK that shoots that idea down in flames! All that makes this truck "not a good deal". Guess I'll keep lookin'.
Tymar intake -
Air LIft airbags -
D60
33" MT -
Hiniker 8' C-Plow
post #5 of 7 (permalink) Old 11-17-2011, 09:23 PM
STILL LEARNING
Bradbilt's Avatar
Re: Stick to Auto
Or just buy it and sell it. I know around here a stick truck brings more $$ than an auto, my about $1000
Bradbilt is offline
post #6 of 7 (permalink) Old 11-18-2011, 11:35 AM
Re: Stick to Auto
Can you put a C6 behind the 7.3? If so you could throught a LoCar shifter on it, re-do the drive shafts and go... but by the time you make the swap you may as well just buy a more expensive auto truck and spend the time you would doing the swap plowing more lots.
I have a white truck...
welchct is offline
post #7 of 7 (permalink) Old 11-18-2011, 03:15 PM Thread Starter
LawnRanger's Avatar
Re: Stick to Auto
My thoughts exactly.
Tymar intake -
Air LIft airbags -
D60
33" MT -
Hiniker 8' C-Plow
