95 no start please help!!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 26 (permalink) Old 11-16-2011, 07:14 PM Thread Starter
Hey guys I'm brand new to powerstrokes. My 95 sputtered and died on me while driving down the road and now wont start . I changed the cam sensor with one from Ford. But it didn't help now people are telling me it's the Ipr. Any advice would be great I can also take pictures thanks . Ron
monroegt is offline
post #2 of 26 (permalink) Old 11-16-2011, 07:27 PM
zilla68's Avatar
Re: 95 no start please help!!!!
you need a scanner, if the tach is moving the cps should be ok, but new ones are known to be bad right out of the package.
batteries fresh? starter cranking hard and fast?
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #3 of 26 (permalink) Old 11-16-2011, 07:52 PM
greenbeast's Avatar
Are you getting a wait to start light? Check the fuses under the hood, you may have a fuel bowl heater shorting out on you and the same fuse controls the IDM so your truck would not start.
greenbeast is offline
post #4 of 26 (permalink) Old 11-16-2011, 08:32 PM
Patrick Feeley's Avatar
Are you getting a Check Engine Light? As greenbeast mentioned, check your underhood fuses (especially #22), and check with a meter as plenty of folks have responded that they checked (only visually) and found out later that the supposedly good fuse was in fact bad. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #5 of 26 (permalink) Old 11-16-2011, 08:37 PM Thread Starter
No check engine light. Tach moves all fuses good. But I will try the test light. Beans performance fuel system
monroegt is offline
post #6 of 26 (permalink) Old 11-17-2011, 04:23 PM Thread Starter
Bump
monroegt is offline
post #7 of 26 (permalink) Old 11-17-2011, 07:35 PM Thread Starter
Checked #22 fuse its all good no fuel at lines at regulator
monroegt is offline
post #8 of 26 (permalink) Old 11-17-2011, 08:19 PM
One Stroke @ a Time
jsnyder7.3's Avatar
First make sure you have power to the fuel pump relay. Beans runs a oil pressure switch on their fuel system. Without a scanner or mechanical guage its hard to see if you're getting oil pressure. Have someone crank the truck and use your test light to see if there is power going through the fuel pump relay. If I'm correct about the wiring of their system there isn't going to be fuel pressure at the rail unless you have oil pressure (its a safety back up in case you loose oil pressure)
97 F350 CCLB 4x4
a bunch of costly things and some bloody knuckles, but a lot of fun to drive!
"Loaded like a freight car, driven like a stock car!"
jsnyder7.3 is offline
post #9 of 26 (permalink) Old 11-17-2011, 08:20 PM Thread Starter
I don't have access to a scanner. I don't know what else to do should I just change the IPR or anything else you guys can think of.
monroegt is offline
post #10 of 26 (permalink) Old 11-17-2011, 08:21 PM Thread Starter
jsnyder would you be able to tell me where to locate that relay? as I said I'm pretty green and didn't install any of these mods.
monroegt is offline
