oil leak!!!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 11-15-2011, 09:55 PM Thread Starter
oil leak!!!!!
got an oil leak on my 7.3 it looks like its comeing from the top drivers back of the engine. anybody got any ideas what it could be???
1996 f250 7.3 guages straightpipe f5 DP TUNER 4:11's
corbread is offline
post #2 of 4 (permalink) Old 11-15-2011, 09:57 PM
Re: oil leak!!!!!
could be a bad vc gasket or it could be the CCV orings
anthony
rockets10510 is offline
post #3 of 4 (permalink) Old 11-16-2011, 02:54 AM
Patrick Feeley's Avatar
Re: oil leak!!!!!
Check the big (2" diameter with a 1/2" square-drive recess) High Pressure Oil Rail End Plug on the end of the head. Also check the turbo pedestal for leakage around it. You can also check the engine valley for oil, although oil leaks there generally will drain down the back of the motor on the passenger side. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #4 of 4 (permalink) Old 11-16-2011, 07:34 PM Thread Starter
Re: oil leak!!!!!
I got to find it you can really smell the oil under a strain!!!
corbread is offline
