exhaust temps. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 11-15-2011, 01:46 AM Thread Starter
exhaust temps.
I've got a 96 f250 7.3 automatic 4wd with a dp tuner chip and guages. I bought camper over the weekend that weighs about 6300lbs. What is a safe exh temp it ran about 1150 to 1200 degrees under a strain but cooled off to about 600 to 900 degress. That is with chip onthe 60hp tow setting. Is that normal? What is the limit b4 melt down thanks for any info
1996 f250 7.3 guages straightpipe f5 DP TUNER 4:11's
corbread is offline
post #2 of 4 (permalink) Old 11-15-2011, 02:10 AM
Re: exhaust temps.
Yep, that's about normal for a stock truck.1250 is the limit but short bursts past that are fine, its the holding it past that temp is when things go bad.
02 f250
countryboyrob is offline
post #3 of 4 (permalink) Old 11-15-2011, 02:55 AM
Nitro41's Avatar
Re: exhaust temps.
Pretty much the Standard is 1250 all day.....anything past that is rolling the dice. I have tapped 1450 a couple times but instantly lift.
97 Single Cab F250 4x4 5 speed
Swapped D-60
Locked front and rear
160 sticks
Wildman Tunes
T500 HPOP
OFE clutch
Linex rockers
35" Toyo M/Ts
and a bunch more...
Nitro41 is offline
post #4 of 4 (permalink) Old 11-15-2011, 10:02 PM Thread Starter
Re: exhaust temps.
thanks for the info!!!!!!!!!!
corbread is offline
