up pipe question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 1 (permalink) Old 11-14-2011, 09:36 PM Thread Starter
Heath
rollingthunder's Avatar
up pipe question
I am installing a d-66 with new uppipes and using the chevy donuts. i have the uppipes in and loosly fitted together. I ma guessing that I need to install the turbo to position the collector and then tighten up all the uppipe bolts. Any tricks or tips to getting to the bolts with the turbo on?
Second question for those who have converted to e-fuel----The rear drivers side I used a AN-6 straight fitting with a 90 on the hose. The fitting fits but the hose pushes the collector out. Any one have the same problem? It looks like I have enough material to shave an 1\8" off the collector .
THanks
2005 250 crewcab king ranch
arps, egr delete,coolant and oil bypass filters
4" turbo back MBRP
A-1000 fuel w\Reg return
Warrne 175\30's
rollingthunder is offline
