Power door locks - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 11-12-2011, 01:05 AM Thread Starter
ANIMOSITY's Avatar
Power door locks
Anyone know where the lock switch gets it power from and what wire?
My truck had a Viper alarm( didn't work, what a jerry rigged mess) when I bought it. Well pulled the tangled mess out today and now the door locks don't work.
the only thing I hate more the troubleshooting electrical, it fixing someone elses wiring hack job.
For those who fought for it, Freedom has a taste the protected will never know!
ANIMOSITY is offline
post #2 of 4 (permalink) Old 11-12-2011, 02:05 AM
Patrick Feeley's Avatar
Re: Power door locks
I would recommend getting an Electrical and Vacuum Troubleshooting Manual (EVTM), it makes working electrical issues easier. The power locks get their power from Circuit Breaker #12 in the underdash fuse panel. The wire is Black with a White trace from the CB through connector C214 and splits to the Master Switch (driver's side) and passenger side switch. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #3 of 4 (permalink) Old 11-12-2011, 01:09 PM Thread Starter
ANIMOSITY's Avatar
Thanks for the help. I plan on getting the book, but was working late on the truck and didn't have time to go out looking. Thanks again.
post #4 of 4 (permalink) Old 03-04-2012, 06:42 AM
steve burris's Avatar
My truck 97 350 has the same problem.It also started after po viper alrm system was removed.Did you ever figure it out?
steve burris is offline
