My New Truck - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 11-11-2011, 04:52 AM Thread Starter
My New Truck
So i just picked up a 1995 f250 PS, and it seems to be exactly what i want except it does not seem to be spooling up the turbo until 3000rpm and extremely gut less in low RPMs. I'm new to the 7.3 so i don't know if is what i should be expecting if not what do i need to look at for probable cause of the no low end power. thanks for any help that you can give me
Irishredneck is offline
post #2 of 6 (permalink) Old 11-11-2011, 05:03 AM
<--Blue Slut
BigBlue7point3's Avatar
Re: My New Truck
My uncle's got a 94 with the same problem.. I don't know what to tell ya but I hope someone here does, I'll be interested to find out also to help him
Justin Zoeller
Early '99 F250
Few odds and ends,
Built not Bought!
BigBlue7point3 is offline
post #3 of 6 (permalink) Old 11-11-2011, 05:53 AM Thread Starter
Re: My New Truck
well im sure its not the problem but i know it needs to be done, im going to change the oil and fuel filter tomorrow and possibly build an intake if i have the time
post #4 of 6 (permalink) Old 11-11-2011, 03:48 PM
Patrick Feeley's Avatar
Re: My New Truck
Might want to check out the compressor blades and shaft for evidence of damage/play. Also check all your intake boot connections, the intake manifold(s)-to-head joints, and the line that runs to the MAP sensor on the passenger side firewall. Cheers!
Patrick Feeley is offline
post #5 of 6 (permalink) Old 11-11-2011, 03:52 PM
95powersmoker's Avatar
Re: My New Truck
Do you have a boost gauge or are you just saying you can't hear the turbo until 3k?
If stock exhaust and stock intake, you probably don't have a boost problem.
Also, these trucks are dogs stock. 170ish rwhp.
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #6 of 6 (permalink) Old 11-11-2011, 04:34 PM Thread Starter
Re: My New Truck
no i dont have a boost gauge yet, i guess that is the next thing i will be buying
