bad grinding noise.. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 11-09-2011, 11:08 PM Thread Starter
cowboy
Stroke&Smokin cowboy's Avatar
My truck has had this bad grinding noise. Sounds like it is coming from the clutch in a way.. but my clutch still works great another no slipping or burning smell.
Today I found that even with the truck shut off an rolling there is a rattling noise commin from the same area.. an wen u kick it in reverse it seams to want to bog down a bit an spin the tires. That's without even applying the fuel peddle..
Stroke&Smokin cowboy is offline
post #2 of 27 (permalink) Old 11-09-2011, 11:35 PM
STILL LEARNING
Bradbilt's Avatar
Re: bad grinding noise..
is that with the clutch in or out?
Bradbilt is offline
post #3 of 27 (permalink) Old 11-10-2011, 12:12 AM Thread Starter
cowboy
That happens wen I'm releasing the cliche peddle wen I'm trying to back up..
post #4 of 27 (permalink) Old 11-10-2011, 12:29 AM
STILL LEARNING
Bradbilt's Avatar
Well that is the way a clutch works. when you let it out, it engages and the truck moves
Bradbilt is offline
post #5 of 27 (permalink) Old 11-10-2011, 12:42 AM Thread Starter
cowboy
Yea I know that.. but it shouldn't be bogging down real bad an trying to spin the tires like u dumped the clutch or something..
post #6 of 27 (permalink) Old 11-10-2011, 12:53 AM
STILL LEARNING
Bradbilt's Avatar
Revers is geared pretty low. What year is your junk?
Bradbilt is offline
post #7 of 27 (permalink) Old 11-10-2011, 12:54 AM
STILL LEARNING
Bradbilt's Avatar
I mean truck
Bradbilt is offline
post #8 of 27 (permalink) Old 11-10-2011, 01:20 AM Thread Starter
cowboy
Its a 94. I've had the grinding noise for bout a week at most an the wheel problem started a few days ago.
post #9 of 27 (permalink) Old 11-10-2011, 01:28 AM
STILL LEARNING
Bradbilt's Avatar
Have you checked any of the fluids since you bought the truck? What wheel problem?
Bradbilt is offline
post #10 of 27 (permalink) Old 11-10-2011, 01:33 AM Thread Starter
cowboy
Yea all my fluids are at proper levels.. an I meant the bogging an rear wheel spinning problem.. could it be the throw out bearing?
