Block heater doesn't work, won't start cold - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 11-07-2011, 06:24 PM Thread Starter
I have a 94 1/2 powerstroke and the block heater quit working. I think the glow plugs are bad, and it won't start when cold. Once it is warm it will start until you leave it overnight and it gets cold again. (I rolled it down the driveway to get it started) Of course I wasn't smart enough to park it where it would roll this time, and I don't have anybody around to help me push it
Anyways I plan on replacing the glowplugs, and then it will probably start, but the block heater doesn't work and it is getting cold out. Anybody know what the problem could be with the block heater? Could it be as simple as a fuse? No markings in the fuse box for which one might be connected to the block heater, but I couldn't find a bad fuse. Anybody know which fuse would go to the block heater?
bearcat is offline
post #2 of 6 (permalink) Old 11-07-2011, 07:00 PM
OBS Stroker
Nodge's Avatar
Re: Block heater doesn't work, won't start cold
There is no block heater fuse. The cord plugs in beside the oil filter. You probably just need a new cord.
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
Nodge is offline
post #3 of 6 (permalink) Old 11-07-2011, 10:18 PM
If you need new plugs and relay, we have new zd-11s and stancor relays in stock and ready to ship.
02 f250
countryboyrob is offline
post #4 of 6 (permalink) Old 11-07-2011, 11:01 PM
'05 Excursion
Term3's Avatar
I've found that an oil pan heater made a big difference in starting.
Term3 is offline
post #5 of 6 (permalink) Old 11-08-2011, 12:56 AM
mandkole's Avatar
We did my neighbors truck last winter for exactly the same thing. Take Rob up on his offer and get the new GPs/relay. You don't want to go into winter wasting power trying to light it with a block heater. Also, dead GPs throw enough resistance that they can kill UVC harnesses.
I got a power cord from a navistar dealer for less than $20.
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
post #6 of 6 (permalink) Old 11-08-2011, 01:54 AM
Power cord for the block heater is generic. NAPA should have them for about the same $20-ish if there isn't a Navistar/Intl dealer nearby.
True, nothing beats new Motorcraft/Beru GPs and a Stancor relay, but before throwing money around, TEST! You can measure the resistance of the plugs, and the voltage drop of the relay, with a $10 (or less) voltmeter. Plus, the meter can tell you if there are any issues with the UVCHs or the connectors on the gaskets themselves; worth knowing even if you're replacing the plugs and/or relay.
madpogue is offline
