Cold starting issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 11-06-2011, 11:57 PM Thread Starter
david212acu's Avatar
Cold starting issue
So, I'm pretty new to the forum. Been reading about all sorts of interesting topics trying to absorb as much as I can. I just bought a 96 f250 PSD from a dealer in Georgia before I moved to upstate New York last month. I've noticed that in the morning when the temp is below 30 or so I turn the key to run, let the glow plugs warm up the engine and then when i turn it over it'll start but it'll surge between 300-600 rpm and it'll do this for a while and not take any throttle input. once it finally warms up it'll run fine. I plugged in my engine block heater for the first time and it didn't seem to help. Any ideas as where to start?
david212acu is offline
post #2 of 6 (permalink) Old 11-07-2011, 02:43 AM
hendricksbus's Avatar
Re: Cold starting issue
have you checked the UVCH?? you may have a bad connection! check for burnt or melted connection! good luck and keep absorbing! as i am.
1996 F-250,Ext.cab,LB,4x4
stock tires
180K,6 pos chip,Open air filter, 3'' down pipe,fpr mod,ccv mod
4.10s gears!
Boost, Pryo and transmission gauges
sonnax shift improver kit
bronco tank mod
hayden cooler for transmission
hendricksbus is offline
post #3 of 6 (permalink) Old 11-08-2011, 02:56 AM Thread Starter
I'm not exactly sure what a UVCH is to be perfectly honest.
post #4 of 6 (permalink) Old 11-08-2011, 03:11 AM
Running at last...
powerstroke cowboy's Avatar
The UVCH would be the.. Under Valve Cover Harness..
How long did you let the block heater pluged in for????
97 CCLB 4x4 ZF6 [email protected]
powerstroke cowboy is offline
post #5 of 6 (permalink) Old 11-08-2011, 10:52 AM Thread Starter
I left it plugged in overnight in the garage. It acts the same though even if I don't plug it in
post #6 of 6 (permalink) Old 11-09-2011, 02:42 AM
Running at last...
If that is the case.. Then I would say there is more to it then Glow Plugs.. Unless your Block heater is bad.. If it was A Glow Plug problem.. Pluging it in over night would have got rid of the Problem.. Or most of it..
I would check all your Valve cover harnesses and pigtails And make shure they are good... Another easy fix can be the Glow Plug Relay switch.. They like to go out somtimes..
