Fuel Starvation? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 11-06-2011, 05:03 PM Thread Starter
Fuel Starvation?
I have a 96 f250. A couple of weeks ago I was driving and suddenly lost power and had a horrible knocking. There wasn't white smoke while I was limping home. Since parking it I have changed the uvc harnesses and valve cover gaskets and went ahead and changed the cps. Its still runs horribly, there is white smoke on startup but it has since I purchased it and its never been a problem before. I really dont want to think injectors but the thought does cross my mind constantly. Any suggestions would be greatly appreciated
Greaser.Life is offline
post #2 of 2 (permalink) Old 11-07-2011, 02:33 AM
hendricksbus's Avatar
Re: Fuel Starvation?
welcome to psn! do you have any fuel leaking in the valley of the engine? if so you may need a fuel pump.
1996 F-250,Ext.cab,LB,4x4
stock tires
180K,6 pos chip,Open air filter, 3'' down pipe,fpr mod,ccv mod
4.10s gears!
Boost, Pryo and transmission gauges
sonnax shift improver kit
bronco tank mod
hayden cooler for transmission
hendricksbus is offline
