97 F350 Tranny fluid check? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 11-05-2011, 09:02 PM Thread Starter
dxp200's Avatar
Hey guys, i'm new so be gentle with me. I just got my first powerstroke and lovin it. It was my dad's and it's a manual. i can't seem to find where to check the transmission fluid level. Does it even have one? And if so where the heck is it.
dxp200 is offline
post #2 of 11 (permalink) Old 11-06-2011, 12:34 AM
Re: 97 F350 Tranny fluid check?
Should be even with the filler plug on the side of the case.
Page 285 in the manual.
https://owner.ford.com/servlet/Conte...FYTe4AodsyAo1g
Okney1lz is offline
post #3 of 11 (permalink) Old 11-06-2011, 01:28 AM Thread Starter
dxp200's Avatar
Yea that manual only shows for a gas engine with an automatic transmission I don't see the 7.3 manual transmission, like mine
dxp200 is offline
post #4 of 11 (permalink) Old 11-06-2011, 04:28 AM
Patrick Feeley's Avatar
Big plug on the driver's side of the transmission (can't miss it). Cheers!
Patrick Feeley is offline
post #5 of 11 (permalink) Old 11-06-2011, 03:22 PM Thread Starter
dxp200's Avatar
Ok, is that located under the truck on the transmission it self? I was looking for a dip stick or so under the hood to check the fluid level for the tranny.
dxp200 is offline
post #6 of 11 (permalink) Old 11-06-2011, 03:31 PM
blacksmokingplumber's Avatar
it has no dipstick. You have to crawl under the truck with a 3/8 ratchet and pull the upper plug to check the level. Usually labeled FILL. Fluid should be right at plugs threads.
2001 F-250 SC/SB 4x4 Auto
"All I want to do is Burp, Puke and Fart, In that order."
"Powerstroke Performance Headquarters!"
blacksmokingplumber is offline
post #7 of 11 (permalink) Old 11-06-2011, 07:10 PM Thread Starter
dxp200's Avatar
Thanks, will do
dxp200 is offline
post #8 of 11 (permalink) Old 07-28-2018, 02:23 AM
So I have a 1997 F-350 with 7.3 and appears dipstick for auto tran is missing
any idea how to replace?
DRKIRK is offline
post #9 of 11 (permalink) Old 07-30-2018, 09:09 AM
Terminator Nation
Try the wrecking yard. Its possible the dealer may be able to order one but chances are slim
old man dave is offline
post #10 of 11 (permalink) Old 07-30-2018, 01:28 PM
Native Texan
masakimm's Avatar
Garage
F6TZ-7A020-GA is the part number it took me almost a year to find one. they are discontinued. Best bet is finding a parts truck somewhere.
Upgrades:
masakimm is offline
