Ca emmisions glow plug module - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 10-30-2011, 05:07 PM Thread Starter
1TONTOY
1tontoy's Avatar
Anyone know if I can use a normal glow plug relay to replace the existing module as long as I hook up the wiring the same and use the existing shunt? Also anyone know a definitive way to test the module? I replaced all my glow plugs yesterday checked my wiring and I am still having cold start issues and throwing a code.
Thanks
97 f-350 7.3 4x4 TS Chip Gauges Tony Wildman 4.10 DIY 6637 3.5" DP exhaust -CAT Mag-Hytec E4OD/4R100 Transmission Pan
2000 EX 7.3 4x4
1tontoy is offline
post #2 of 9 (permalink) Old 10-30-2011, 06:57 PM
Desert Rancher's Avatar
Re: Ca emmisions glow plug module
As I recall, the relay itself is the same. Cali added the shunt module and related wiring to sense glow plug amperage.
DR
97 F250HD (Cal. model) Auto, Ext. Cab XLT, 4x4, long bed
Desert Rancher is offline
post #3 of 9 (permalink) Old 10-30-2011, 07:04 PM
Either jump the terminals with a screw driver or test with a multi meter. I replaced my cal truck with stancor years ago. Trouble free
Got4wd is offline
post #4 of 9 (permalink) Old 10-30-2011, 07:23 PM
Did you keep the shunt? If so, got pics?
Thanks~
DR
post #5 of 9 (permalink) Old 10-31-2011, 04:02 PM
What code are you throwing?
madpogue is offline
post #6 of 9 (permalink) Old 11-01-2011, 05:19 AM
Thanks~
DR
Nope no shunt took it off. I will take some pics and post
Got4wd is offline
post #7 of 9 (permalink) Old 11-01-2011, 05:19 AM
I might have a soft code but no cel light
Got4wd is offline
post #8 of 9 (permalink) Old 11-01-2011, 06:40 AM
Terminator Nation
On one of these forums someone had a set of pictures of the Stancor with the California shunt installed. Just can't find it now, it was within the last month. I imagine without the shunt you would be getting some sort of glow plug failure code since without the shunt it would be the same as no glow plug current sensed.
old man dave is offline
post #9 of 9 (permalink) Old 11-01-2011, 07:09 AM
Here it is:
Stancor with Shunt!!!! This is how to wire it. - PowerStrokeNation : Ford Powerstroke Diesel Forum
Yes, the PCM should sense the missing shunt and show a code. I tried to install a switch to control the GPR (as others have done) and it caused a code.
