truck wont start please help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 10-30-2011, 03:23 PM Thread Starter
Black Beauty 7.3's Avatar
Hey all, so i tried to start my truck this morning and i turn the key over and nothing. It wont even try to turn over like the batteries are dead. But all my lights and radio and etc go on fine. I tried to jump start it...same thing nothing. I have on idea where to start. If it helps there is about a foot of snow here. Thanks. Any help is appreciated.
Tony
1996 Ford f-350 7.3l psd Tony Wildman 6 pos chip, 6637 intake, Autometer gauges, 6" silverline aussie stacks
1995 F-Super Duty 5 speed 6637 intake, straight piped
Black Beauty 7.3 is offline
post #2 of 10 (permalink) Old 10-30-2011, 03:36 PM
hendricksbus's Avatar
Re: truck wont start please help
how was it starting before today?
1996 F-250,Ext.cab,LB,4x4
stock tires
180K,6 pos chip,Open air filter, 3'' down pipe,fpr mod,ccv mod
4.10s gears!
Boost, Pryo and transmission gauges
sonnax shift improver kit
bronco tank mod
hayden cooler for transmission
hendricksbus is offline
post #3 of 10 (permalink) Old 10-30-2011, 03:44 PM
jrf350
jrf350's Avatar
if its auto try putting it in neutral if its manual it could be the clutch interlock switch. do your gauges and wait to start light come on i have seen the steering column break internaly it doesnt take very long to unbolt your ignition switch underneath the steering column you can start the truck with the ignition switch when its unbolted and find out best off luck
jrf350 is offline
post #4 of 10 (permalink) Old 10-30-2011, 04:05 PM
Patrick Feeley's Avatar
How old are the batteries? Check all your battery cable connections (both ends) to make sure they are clean and tight. Also, you may want to have your starter bench-tested. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #5 of 10 (permalink) Old 10-31-2011, 04:05 PM
Auto or manual tranny? Do you hear any click sound from under the hood?
madpogue is offline
post #6 of 10 (permalink) Old 10-31-2011, 04:11 PM
95powersmoker's Avatar
Tony
Had the same issue on my SD the other day.. Test the batteries... My lights and everything came on fine but no where near enough CCA's to start the truck.
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #7 of 10 (permalink) Old 10-31-2011, 05:12 PM Thread Starter
this was happening before i had to adjust my tranny cable. the tranny wasnt in park or neutral when i tried to start it stupid me.
post #8 of 10 (permalink) Old 10-31-2011, 10:09 PM
easy thing to try first jump across the silanoid or how ever you spell it if it turns over its bad if still nothing then try your starter next
derbyfreak84 is offline
post #9 of 10 (permalink) Old 11-01-2011, 01:09 PM Thread Starter
i got it i just had to put the truck in park haha oops.
post #10 of 10 (permalink) Old 11-01-2011, 09:11 PM
"Doctor, it hurts when I do this....."
madpogue is offline
