no start started fine then died and no start or wait to start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 10-29-2011, 01:32 AM Thread Starter
jrf350
jrf350's Avatar
the pcm went bad and we changed it it ran fine for a week then today i started the truck it fired right up like usual then it was sitting there warming up and it hicuped maybe twice then smothed out and a few minutes later hicuped again and died tried to restart it and no wait to start light no tach movement and no start turns over great but nothing. took a cumputer and idm out of running truck and no change . truck has newer icp cps glow plugs and only about 9000 miles on a rebuilt motor please help im lost
jrf350 is offline
post #2 of 11 (permalink) Old 10-29-2011, 01:37 AM Thread Starter
jrf350
jrf350's Avatar
Re: no start started fine then died and no start or wait to start
ok i was wrong it didn,t die it hicuped a couple times and we shut it down and it wont start any ideas
jrf350 is offline
post #3 of 11 (permalink) Old 10-29-2011, 01:39 AM Thread Starter
jrf350
jrf350's Avatar
its a 94 zf5 f350 cclb with 214000 miles on the truck and 9000 on motor
jrf350 is offline
post #4 of 11 (permalink) Old 10-29-2011, 05:05 AM
Modded by a Chevy Express
Alberta 7.3's Avatar
Have you checked all the fuses? The fuel heater can short out in the filter bowl. It will pop fuse 22 in the underhood power box. Without no PCM power, you won't have a WTS light or tach movement, but the starter will still roll over.
96 F250 SC/SWB/4X4 XLT Just a 7.3 with a bunch of the usual bolt-on crap
08 F350 CC/LWB/4X4 DRW Lariat
Alberta 7.3 is offline
post #5 of 11 (permalink) Old 10-29-2011, 05:06 AM
Patrick Feeley's Avatar
If you are not getting a WTS light, check underhood fuse #22 (with a meter ... don't just look at it) and if it has blown, unplug the fuel heater, replace the fuse and try again. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #6 of 11 (permalink) Old 10-29-2011, 05:24 AM Thread Starter
jrf350
jrf350's Avatar
thanks it was #22 FUSE I thought i checked em all but i musta missed that one truck is running again thanks again
jrf350 is offline
post #7 of 11 (permalink) Old 10-29-2011, 05:40 AM
If you didn't disconnect the fuel heater as Patrick admonished, it'll blow (and the engine will stall) again.
You also need to fix the SHIFT, COMMA and PERIOD keys on your keyboard. This isn't chat or txt.
madpogue is offline
post #8 of 11 (permalink) Old 10-29-2011, 05:55 AM
Puntuation, he's doing it wrong.
post #9 of 11 (permalink) Old 10-30-2011, 03:53 PM Thread Starter
jrf350
jrf350's Avatar
sorry guys im not very good with a computer and not a writer i dont know what chat is and seldom text. I appologize for my lack of proper english but i do appriciate all your help thanks again. Oh yeah the first thing i did was disconect the fuel heater.
jrf350 is offline
post #10 of 11 (permalink) Old 10-31-2011, 11:01 PM
I think I may have the same problem with the fuse blowing on my 97 F350. Does anyone have a pic showing what exactly must be disconnected at the fuel heater before replacing the fuse?
jfmoore79 is offline
