I dont have a clue whats wrong.. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 10-28-2011, 07:14 PM Thread Starter
Ok so the title pretty much says where im at right now.. so heres my problem(s)
getting code p0500
truck will not start...
speedo and odometer only work if i press on the brakes
abs light is on
the light on the shifter is flashing
transmission is shifting crazy
also i have a lockup switch installed with a light that tells me its on.. the switch is off but the light is still lit telling me that its in lockup
also i changed the sensor in the rear end..
PLEASE HELP !
Mike For Mayor is offline
post #2 of 17 (permalink) Old 10-28-2011, 08:21 PM
Re: I dont have a clue whats wrong..
Take out the TC lock up switch and see what it does.
02 f250
countryboyrob is offline
post #3 of 17 (permalink) Old 10-28-2011, 08:23 PM Thread Starter
Still nothing.. I can start it by jumping the solenoid but that's it
US ARMY 05-Current
OIF/OEF/ONE/KFOR 06-08
96 F350
97 Jeep Wrangler
02 VW Golf GTI
post #4 of 17 (permalink) Old 10-28-2011, 09:47 PM
Are you jumping the SOLENOID (on the starter) or the RELAY (on the fender). So when you say "truck will not start", it's not even cranking? And you have to jump the fender relay?
This is all pointing to the range selector switch on the tranny (aka MLPS, aka neutral safety switch). Try starting it in neutral. Also try holding the key in START while nudging the shifter from Neutral toward Reverse and toward Drive. ***NOTE*** - Of course, make SURE you've got your foot FIRMLY on the brake, might even want to hit the parking brake, while you do this. If that switch is out of adjustment (which the above procedure is meant to determine), it could start with the tranny in gear, and as soon as the TC engages, you're truckin'.
madpogue is offline
post #5 of 17 (permalink) Old 10-28-2011, 09:47 PM Thread Starter
The p0500 code says that the pcm could be bad.. could this be my problem?
US ARMY 05-Current
96 F350
97 Jeep Wrangler
02 VW Golf GTI
post #6 of 17 (permalink) Old 10-28-2011, 09:52 PM Thread Starter
Yeah im jumping the fender relay and I have tried the holding the key on and slowly running it through all the gears to start and it does nothing.. all it does is click once like the starters bad.. but its not I had it tested
US ARMY 05-Current
96 F350
97 Jeep Wrangler
02 VW Golf GTI
post #7 of 17 (permalink) Old 10-28-2011, 09:53 PM Thread Starter
Also when you drive it it slams into gears and when you hit the brakes the speedo and odometer work
US ARMY 05-Current
96 F350
97 Jeep Wrangler
02 VW Golf GTI
post #8 of 17 (permalink) Old 10-28-2011, 10:32 PM
Could be that the whole switch connector on the tranny has come disconnected. Slide under and take a look at it. IIRC, it's on the driver's side of the tranny.
madpogue is offline
post #9 of 17 (permalink) Old 10-28-2011, 10:41 PM Thread Starter
Ok I have checked and its connected firmly
US ARMY 05-Current
96 F350
97 Jeep Wrangler
02 VW Golf GTI
post #10 of 17 (permalink) Old 10-28-2011, 11:17 PM
t.land's Avatar
i just installed a new trans and when I took it out for the first drive, the truck had the same issues, ABS light on and the Overdrive light was flashing. At what I considered normal pedal position for typical acceleration, I was only at roughly 50% the speed I would usually be at. I jumped under the truck, unplugged the switch connector and then plugged it in again and all lights were off and it shifted and acted perfectly normal. Not saying this is the case for you, but that was my experience.
1997 F250 XLT CC/SB 7.3 - TS 6-position with Swamps tunes, John Wood Towmaster Trans, Tru-Cool, D60 with Sky RSK, Hypermax 5" exhaust, 3" DP, gauges, 18" Procomp 1069's, 325/65/18 Hankook Dynapro ATM, afe stage II
t.land is offline
