**** Attn: IVS & TPS Source**** - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-27-2011, 02:07 PM Thread Starter
Desert Rancher's Avatar
This is the Manufacturer and P/N for the Ford IVS. It is the actual part made for Ford.
I had purchased all the existed stock before and was told that's it. Now it appears that they have run another batch.
Look here:
http://www.onlinecomponents.com/cutl...tml?p=11071279
Cutler Hammer/Eaton SS22BW32-330Y
TPS - Dorman
Dorman makes the aftermarket TPS. I'm sure it is a good part.
Dorman Products - Search Results
97 F250HD (Cal. model) Auto, Ext. Cab XLT, 4x4, long bed
Desert Rancher is offline
post #2 of 7 (permalink) Old 10-28-2011, 10:17 PM
Russ's Avatar
Re: **** Attn: IVS & TPS Source****
linky no worky
Stormtrooper:: 1997 F-350 CC SRW PSD XLT 4X4: Baby Swamps, Wildman, SD Intercooler, CCV Mod, shimmed FPR, BTS, Baldwin air filter,triple pillar pod with Isspro gauges, 4" exh, SD dual tensioner mod, diamond cut headlights, Hadley air horns,
Russ is offline
post #3 of 7 (permalink) Old 10-28-2011, 10:35 PM
^^^^^ Looks like the OP pasted the text in front of a link from another forum, rather than the link itself.
Re. the Dorman part - anyone know if it would work on a '94.5 or '95? Dorman only qualifies it back to '96, and even the Ford part number for the whole assembly changed in '96.
madpogue is offline
post #4 of 7 (permalink) Old 10-28-2011, 11:46 PM
Terminator Nation
The Dorman TPS units are iffy. Of the three OBS ones I've seen, two worked, one didn't, quality control seems spotty. The factory replacement ones were not much better. I had to get three new pedal assemblys to get a good one. Try explaining that to the dealer parts guy that their new $350 parts are bad. Two of them gave up after 8 and 10 miles of driving; reverting to idle state on the side of the road with the TPS going open on resistance. However they were considered to be part of the emissions systems so they had the extended warranty for smog parts.
The split for the application, the Dorman 699-201 SD units are different than the OBS ones, the plugs are different. I think all of the OBS ones are the same, F6 would just be a factory update part number in '96 for the original F4 ('94) part.
old man dave is offline
post #5 of 7 (permalink) Old 10-29-2011, 05:14 AM Thread Starter
Sorry 'bout that. I have purchased this part before, it is the real deal.
Here it is:
CUTLER HAMMER/EATON SS22BW32-330Y is in stockOnlinecomponents.com
Mfgr: Cutler Hammer/Eaton
P/N: SS22BW32-330Y
post #6 of 7 (permalink) Old 10-30-2011, 05:16 AM
Terminator Nation
That's cheap enough compared to a whole throttle assemby.
The IVS linkage can be adjusted to minimal dead spot off idle for a better throttle feel by bending the actuator tab closer to the IVS switch. Just don't want to go too far, the switch has to be able to reset (click when the pedal is going to idle position and again when coming off of idle, minimizing this gap reduces the dead spot off of idle. If the switch does not click in both directions then the engine will remain in idle state when depressing the pedal, not good when pulling out into traffic.
There is a procedure to adjust the TPS for true full throttle signal output but thats a whole different post.
post #7 of 7 (permalink) Old 01-26-2012, 06:08 AM Thread Starter
Look here: **here is the updated link**
TPS - Dorman
I updated the link for the IVS.
~DR
