97 powerstroke takin its time. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 10-27-2011, 12:31 PM Thread Starter
Heartbroke Powerstroke's Avatar
I bought this truck a little over a week ago and have been working the bugs out of it. This is my first diesel powered truck so there's a lot of stuff I don't know. So here's my question... when I turn the key everything appears to be fine, no check engine light, the wait to start light comes on for a few seconds... It all seems good. When I crank her over it takes a good THREE seconds before she fires... Is this normal? I'm just kind of worried about what will happen when it gets cold out... My gp relay checks out fine... So its not that... Any ideas? Hey if its normal than just tell me to stfu, and we can all carry on forgetting I even asked... Sometimes I'm a bit anal... But she does run great! Can't complain about that... She just takes her time gettin out of bed. Oh BTW... It will do the same thing even when it been warmed up and then restarted...
Heartbroke Powerstroke is offline
post #2 of 15 (permalink) Old 10-27-2011, 02:04 PM
Moderator
PsRumors's Avatar
Re: 97 powerstroke takin its time.
stfu.....lol
When I was on the mechanical fuel pump mine would have to turn over a few times before cranking. I don't think you are experiencing anything abnormal.
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #3 of 15 (permalink) Old 10-27-2011, 02:13 PM
so many trees
sargepep56's Avatar
its normal. sometimes even my 01 takes a bit to crank over
some stock truck from washington state
sargepep56 is offline
post #4 of 15 (permalink) Old 10-27-2011, 03:26 PM
95powersmoker's Avatar
Could be a worn starter...
My OBS starts right up every time unless it's under 30* outside... Then you have to expect a little crank time...
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #5 of 15 (permalink) Old 10-27-2011, 03:30 PM
psdmike's Avatar
Normal
1997 F350 Crew Cab, 7.3, 4x4, 5SP Short Shift kit, 5" RSK SD V Code springs, DIY Intake, 5" Exhaust with 30" FTE Resinator, intercooled, TS chip.
psdmike is offline
post #6 of 15 (permalink) Old 10-27-2011, 04:24 PM
Three or four TURNS (maybe one second) is normal. Three full SECONDS is NOT. Think about how long a second is.
Have you measured the resistance of the glow plugs themselves? Inspected the wiring to the valve covers?
Once it starts, does the voltmeter stay left-of-center for a minute or two, and then swing to the right?
madpogue is offline
post #7 of 15 (permalink) Old 10-27-2011, 05:12 PM Thread Starter
Haven't messes with the glow plugs at all... But would the glow plugs being bad, still have an affect if it does the same thing when warm? And three seconds is a pretty long time...
post #8 of 15 (permalink) Old 10-27-2011, 05:45 PM
1 second is more normal. could be as simple as weak batteries or starter or corroded connections or wires.
donthelegend is offline
post #9 of 15 (permalink) Old 10-27-2011, 06:18 PM Thread Starter
It turns over pretty fast and strong...
post #10 of 15 (permalink) Old 10-27-2011, 06:21 PM
Freddie
FreddieZ's Avatar
Mine does that madpogue, once I start it the volt meter stays left of center for about a minute, what causes that?
FreddieZ is offline
