another miss of rough idle question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-27-2011, 12:30 PM Thread Starter
Angry another miss of rough idle question
I have a 93 CC I swaped out the IDI And put in a 96 PSD.
did a total rebuild on it.
Bored, balanced.
Studs
Cometic Gaskets
SD Turbo
Intercooler
Swamps IDM
Baby Swamps
New Injector Cups
Smith Brothers Push Rods
Comp Cams Springs
17* HPOP
New Ford IPR
Regulated Fuel
Electric Fuel
Dp F5
Also converted the old 2 plug style VC Gaskets to the newer 1 plug with all new Ford stuff..
Now my question is ..
The other day just out of the blue it starts kinda seaming like it was running with a dead hole...
Thought maybe it was a fuel issue..
So I changed my fuel filters..
Didnt change..
Swapped the IDM..
Didnt change..
Ran a buzz test..
All good..
Ran a contrabution test..
All good..
next thing I know it is running Good...
Picked my son up after School and going up a hill it seamed to miss and the kept missing just like before..
Swapped the IDM Again..
Didnt change.
Ran the buzz test..
All Good
Did the Contrabution test 2 more times and both are saying something about cyl. 1 and 2
Oh .. no CEL OR CODES..
Want Next...
I was thinking UVC Harness, but isnt cyl 1 and 2 on differant sides??
I was planning on a 5 hr trip 1 way to get a 24' enclosed trailer Saturday..
Need HELP..
Thanks
John
metrojd is offline
post #2 of 5 (permalink) Old 10-28-2011, 05:20 AM
Re: another miss of rough idle question
Fuel pressure?
-John-
1996 F-250 Ext Cab Long Bed 4x4 w/ a few mods
jmsmith76 is offline
post #3 of 5 (permalink) Old 10-28-2011, 11:30 AM Thread Starter
I had issues with the gauge I mounted on the Reg. isnt working..
I also forgot to mention that I did the swap aprox 12,000 miles ago,,
Trouble free since the swap,, for the most part..
metrojd is offline
post #4 of 5 (permalink) Old 10-28-2011, 02:08 PM
Fixing Broken Stuff
toolmangary's Avatar
Do a cylinder contribution test when it is running bad, if it doesn't pick up a bad cylinder the first time do it again. I have had to do cct's a few (once in a while) times to find the problem hole. It sounds like you have a injector problem.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #5 of 5 (permalink) Old 10-29-2011, 01:12 AM Thread Starter
I Talked to Jonathon @ Swamps..
He is thinking the Same thing and suggested doing the Same..
Also told me when I figure it out thay would get me replacement inj. out right away if that is teh problem..
Thanks
John
metrojd is offline
