need help fuel heater connector - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-27-2011, 12:06 AM Thread Starter
jkrum10238's Avatar
95 f250 my fuel heater connector/sensor/plug is pouring out fuel does anyone have part number for it or what its called in the ford dealer computer i called two dealerships they don't even know what im talking about so frustrating thanks
95 Powerstroke F250 4x4 Automatic. Schwitzer wheel and banks down pipe, straight pipe, 22k mod, fuel pump shim.
jkrum10238 is offline
post #2 of 5 (permalink) Old 10-27-2011, 01:15 AM
Re: need help fuel heater connector
Part Number
9J294 External fuel heater connector with O-ring. Located on side of housing.
9S281 Is the water in fuel sensor and O-ring
Found these on Fordparts.com in under a minute.
Okney1lz is offline
post #3 of 5 (permalink) Old 10-27-2011, 02:25 AM Thread Starter
jkrum10238's Avatar
thank you never knew of that website much appreciated
post #4 of 5 (permalink) Old 10-27-2011, 07:30 AM
LiftedSuzuki's Avatar
Plug it! 1/8" NPT
1995 F-250 7.3L 5 Speed, 4" Lift, 35" Toyos, Straight Pipe, DIY 6637 Intake, TS Chip with PHP Tunes, Glowshift Gauges
LiftedSuzuki is offline
post #5 of 5 (permalink) Old 10-29-2011, 04:59 AM
Patrick Feeley's Avatar
The Fuel Heater connection (kind of a "thermostat" for the fuel heater ... is not just a straight feed-through), is sealed by an o-ring. Here's the part number:
Fuel Heater Thermostat
(Ford) F4TZ-9J294-A
Get it from someplace like Tousley Ford Parts. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
