temp guage problem. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 10-26-2011, 01:48 PM Thread Starter
cowboy
Stroke&Smokin cowboy's Avatar
Unhappy temp guage problem.
Were does the factory temp guage hook up on a 7.3? Mine has seemed to quit working..
Stroke&Smokin cowboy is offline
post #2 of 9 (permalink) Old 10-26-2011, 03:13 PM
Cratos's Avatar
Re: temp guage problem.
the sending unit is on top of the water pump .
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #3 of 9 (permalink) Old 10-26-2011, 06:31 PM Thread Starter
cowboy
OK. Thanks.. is it worth replacing or should I just go aftermarket?
post #4 of 9 (permalink) Old 10-26-2011, 10:30 PM
It's more likely the gauge head in the cluster than the sender. The cluster is "segmented"'; you can get just that segment (the one with the temp gauge and oil "gauge") at LMC, or pull one off a junkyard truck. Or go aftermarket and use that hole for the aftermarket sender. I'd love to see a mod of the OEM cluster segment with an aftermarket gauge head in its place.
madpogue is offline
post #5 of 9 (permalink) Old 10-26-2011, 10:45 PM
First what makes you say that the temp gauge quit working........
02 f250
countryboyrob is offline
post #6 of 9 (permalink) Old 10-27-2011, 10:59 PM Thread Starter
cowboy
Well it worked for bout a week after I bought the truck.. now it won't move ecept on the occasion it will rise to the normal line for a short time an drop again..
post #7 of 9 (permalink) Old 10-27-2011, 11:32 PM
Mine used to do that, it would stay around the N and O.
02 f250
post #8 of 9 (permalink) Old 10-27-2011, 11:40 PM
95powersmoker's Avatar
When I first bought my OBS... The gauge would barely move, replaced the sensor and the Tstat and wahlah, gauge sits in the middle/left of the NORMAL and i got lots of heat...
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
post #9 of 9 (permalink) Old 10-28-2011, 09:10 PM Thread Starter
cowboy
I may have to try that.. mine doesn't even hardly rise off the C but I seem to have decent heat..
