steering on F350... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 10-24-2011, 01:11 AM Thread Starter
cowboy
Stroke&Smokin cowboy's Avatar
Question steering on F350...
What is the best steering setup for a lifted f350??
Stroke&Smokin cowboy is offline
post #2 of 18 (permalink) Old 10-24-2011, 01:14 AM
STILL LEARNING
Bradbilt's Avatar
Re: steering on F350...
Depending on the lift, either stock or high steer
Bradbilt is offline
post #3 of 18 (permalink) Old 10-24-2011, 01:57 AM Thread Starter
cowboy
Mine has the cross bar steering on it now an it seems to pop wen I turn. But its not binding up an all the joints are in great shape.
post #4 of 18 (permalink) Old 10-24-2011, 02:48 PM
STILL LEARNING
Bradbilt's Avatar
Well there is something worn.
Bradbilt is offline
post #5 of 18 (permalink) Old 10-25-2011, 01:24 AM Thread Starter
cowboy
Yea I'm gonna have everything new in this damn thing before its over..
post #6 of 18 (permalink) Old 10-25-2011, 02:41 AM
Check the panhard bar. Mine would pop as I turmed, I have stripped a heim loose from its sleeve
96 CCLB XLT, Napa BHAF, TS 6pos, glow shift guages (pyro boost trans), 3" downpipe, 4" pipes. 6lift, 325/85 XML.
84 K5 - LQ9 swap (6.0) 4 speed detroits, 38's...
I'm a Newb ....and I accept it.
K5383 is offline
post #7 of 18 (permalink) Old 10-25-2011, 04:02 PM Thread Starter
cowboy
What exactly is the panhard bar.
post #8 of 18 (permalink) Old 10-25-2011, 05:22 PM
Goes from a bracket below the engine crossmember, to the drivers side of the axle.
K5383 is offline
post #9 of 18 (permalink) Old 10-25-2011, 05:33 PM
biggreen96's Avatar
Its more commonly known as the track bar
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
biggreen96 is offline
post #10 of 18 (permalink) Old 10-25-2011, 05:53 PM
STILL LEARNING
Bradbilt's Avatar
Goes from a bracket below the engine crossmember, to the PASSENGER side of the axle.
There, I fixed that for you
Bradbilt is offline
