SD Transfer case into OBS? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-21-2011, 08:52 PM Thread Starter
DIESELdog...
TravisT's Avatar
Will a SD transfer case bolt up to the 5 speed ZF transmission on a 96-97 OBS???
1997; New 5 Speed, New Long Block .30 over, Mahle piston Teflon skirt, Stelite valves/seats, Smith Bro Push Rod, HFHV IDM, ARP studs, 910 springs, 238/80; Gearhead Tunes; Adrenalin; S366; Turbo blankie; Fluidampr; Irate fuel; 6.0 Cooler+fan, Coolant Filter; Caltracs; GearVendor, TrueTrac, TrueBeast, never perfect. Need 06+ Axles.
TravisT is offline
post #2 of 5 (permalink) Old 10-22-2011, 02:01 AM
STILL LEARNING
Bradbilt's Avatar
Re: SD Transfer case into OBS?
IIRC No. Different spine count and different diameter
Bradbilt is offline
post #3 of 5 (permalink) Old 10-22-2011, 02:34 AM Thread Starter
DIESELdog...
TravisT's Avatar
I knew you'd know. Thanks.
TravisT is offline
post #4 of 5 (permalink) Old 11-07-2011, 10:25 PM
My buddy bolted a SD transfer case to a ZF5... Worked fine
97 CCSB F250
stage 1 injectors
5 speed
4" straight pipe
Redline7.3 is offline
post #5 of 5 (permalink) Old 11-07-2011, 10:31 PM
STILL LEARNING
Bradbilt's Avatar
That is odd. I have a 271 SD t-case and All it fits is a zf6. Maybe an auto is different
Bradbilt is offline
