Possible PCM removal? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 10-20-2011, 12:54 PM Thread Starter
PSN local
SouthJerseyStroker's Avatar
So i just ordered a Phoenix 6 position from PHP and was reading some about cleaning the terminal on the pcm before installing the chip. I read that some people actually took it out to clean it. Is taking the PCM out a pain? and is it worth doing to get into the terminals better?
97 7.3
PHP Phoenix
IDM mod
AFE Big Boost
06 SD rear springs
Bilstein 5100s
3" MBRP downpipe
4 inch lift
Glowshift gauges- trans temp, boost, egt
SouthJerseyStroker is offline
post #2 of 18 (permalink) Old 10-20-2011, 01:12 PM
STILL LEARNING
Bradbilt's Avatar
Re: Possible PCM removal?
YES. remove it thru the drivers fender well. This way you can see what you are doing as not to take the gold plating of the terminals, or not clean enough
Bradbilt is offline
post #3 of 18 (permalink) Old 10-20-2011, 01:14 PM
I removed mine to clean it. From what I have seen some problems with a chip stem from the terminals not being clean enough.
f250towrig is offline
post #4 of 18 (permalink) Old 10-20-2011, 01:46 PM
Mine was a pain in the ass to remove, it has to come out the fender well area. I used a big crow bar to push down the plastic wheel well to gain enough clearance.
gsxr1216 is offline
post #5 of 18 (permalink) Old 10-20-2011, 08:45 PM
It's pretty easy to remove. Take out some of the screws in the rear of the wheel well, then pull it down as far as you can to make room to slide out the PCM. It will be 100 times easier to clean the terminals properly if you take it out.
-John-
1996 F-250 Ext Cab Long Bed 4x4 w/ a few mods
jmsmith76 is offline
post #6 of 18 (permalink) Old 10-21-2011, 04:57 PM
Once out I split the case and took a very sharp small screw driver and carefully remove the waxy/plastic coating from each terminal of the chip interface be careful not to remove any tin off the terminal connectors. I also removed the waxy keerap layer that is between the tin connectors. Once done reassemble install chip into socket and duct tape to ensure it will not vibrate lose. Took me about an hour to completely clean interface socket.
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10s 37Ē Toyo R/Ts intake, FFD 205/30s, DP 4Ē exhaust DIY E-fuel, ZF-5 now
lights: VisionX & HID projectors in headlights.
JCart is offline
post #7 of 18 (permalink) Old 10-21-2011, 05:40 PM Thread Starter
PSN local
Cool guys thanks! Much appreciated!
97 7.3
PHP Phoenix
IDM mod
AFE Big Boost
06 SD rear springs
Bilstein 5100s
3" MBRP downpipe
4 inch lift
post #8 of 18 (permalink) Old 10-21-2011, 07:57 PM
If you can solder good or know someone who can, I would get them to build the contacts up a little bit. When I did mine I scraped it down a little too much so I just went ahead and scraped it somemore and then had my buddy solder the contacts and the chip fits on there really tight.
-John-
post #9 of 18 (permalink) Old 10-21-2011, 09:33 PM
Terminator Nation
Put a length of broomstick from the bottom of the hood hinge to the plastic wheelwell, lower the hood carefully until the wheelwell dents enough to allow the PCM to be removed. (It pops back when pressure is removed). My screws would not come out, so I had to do the stick trick.
Just have to disconnect the plug and remove the rubber retaining ring to remove the PCM. Drop the parking brake assembly to access the socket for the chip from inside the cab. Scotchbrite pad will gently remove the coating on the tinned surfaces. Just don't remove any tin/coating beyond what it takes to make it shiny.
old man dave is offline
post #10 of 18 (permalink) Old 10-22-2011, 07:05 PM Thread Starter
PSN local
thanks for the hint/tricks. well see how they work when the chip comes. i cant wait!
97 7.3
PHP Phoenix
IDM mod
AFE Big Boost
06 SD rear springs
Bilstein 5100s
3" MBRP downpipe
4 inch lift
