Wantin to switch to a 6speed - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 47 (permalink) Old 10-20-2011, 12:43 PM Thread Starter
cowboy
Stroke&Smokin cowboy's Avatar
Is it possible or hard to switch from a five speed to a six speed in my 94 psd? What all would need changed?
Stroke&Smokin cowboy is offline
post #2 of 47 (permalink) Old 10-20-2011, 12:45 PM
STILL LEARNING
Bradbilt's Avatar
Re: Wantin to switch to a 6speed
Welcome to PSN
There is a search feature that is very helpful
ZF6 Speed Swap into a 97 OBS - PowerStrokeNation
Bradbilt is offline
post #3 of 47 (permalink) Old 10-20-2011, 06:07 PM Thread Starter
cowboy
Thanks.
post #4 of 47 (permalink) Old 10-21-2011, 06:12 PM Thread Starter
cowboy
I can't realy find anything on goin from a 5 speed to a 6six speed.. cannot anyone help?
post #5 of 47 (permalink) Old 10-21-2011, 06:16 PM
GoNavy!
DcMoore999's Avatar
Originally Posted by diesel_brad View Post
Welcome to PSN
He's putting a 6 speed into OBS..... What else do you need to know? you need the plate that goes in between the engine and the tranny because it is different than the five speed.
2000 F-250, RCLB, Auto!!
DcMoore999 is offline
post #6 of 47 (permalink) Old 10-21-2011, 10:03 PM
I think the OP's question is - starting from a ZF5 (rather than an auto), what needs to be changed? Implies several sub-questions:
* Can you use the existing shifter?
* Can you use the existing clutch? (I'd say, who cares? When you've got it apart, install a fresh clutch kit.)
* Can you use the existing flywheel? - Another possible who-cares. If it's on the original dual-mass flywheel, this is the time to swap in a single-mass.
* Can you use the existing pedal and/or hydraulics? (Is a ZF6 internal-slave?)
* What about the PCM? - This one's easy; unlike an auto-manual swap, you can use the existing PCM and don't need to burn anything. The PCM doesn't interface with the manual tranny at all.
There's surely more (driveshaft, t-case if 4x4, etc.).... So it's not quite the same as an auto-to-manual swap.
madpogue is offline
post #7 of 47 (permalink) Old 10-21-2011, 11:56 PM
I know it was posted on here before but there isnt much difference between the zf5 and zf6, the gear ratios were so close to being the same. Can remember of the top of my head where it was posted.
02 f250
countryboyrob is offline
post #8 of 47 (permalink) Old 10-22-2011, 02:02 AM
All the ZF-6's I ever drove were geared so low I never used 1st gear. So I basically drove it like it was a 5-speed. Guess if you're doing a lot of heavy towing 1st would be helpful, but man 1st is LOW.
lossscause is offline
post #9 of 47 (permalink) Old 10-22-2011, 02:06 AM
STILL LEARNING
Bradbilt's Avatar
Zf5 s42 (87-95)
1st Gear:4.14
2nd Gear:2.37
3rd Gear:1.42
4th Gear:1.00
5th Gear:0.77
Rev Gear:3.79
Zf5 s47 (96-97)
st Gear:5.08
2nd Gear:2.60
3rd Gear:1.53
4th Gear:1.00
5th Gear:0.77
Rev Gear:4.66
Zf6
1st Gear:5.79 (99-??)
2nd Gear:3.31
3rd Gear:2.10
4th Gear:1.31
5th Gear:1.00
6th Gear:0.72
Rev Gear:5.23
Bradbilt is offline
post #10 of 47 (permalink) Old 10-22-2011, 01:41 PM Thread Starter
cowboy
Well I'm not gonna use this truck to pull anything.. I'm just looking to get a bit more power an fuel economy. It has a 6 in lift an I'm thinking bout goin to a 10. So what tranny would be better? An could I use my old trans case?
