Hard Brake Pedal - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-19-2011, 12:54 AM Thread Starter
HondaTypeRk20's Avatar
Hard Brake Pedal
Is it the vacuum pump, or master cylinder? Or something else?
Brake pedal is very hard, and is very hard to stop the truck. I have auto locking hubs and 4wd works fine though, at least I dont noticed any difference. Vacuum pump and master cylinder looks like original equipment, but im not for sure.
I just dont feel like wasting the money on something I don't need when its something else.
1993 Ford F-250 7.3 IDI (TRADED)
1994 Ford F-350 460 (TRADED)
1995 Ford F-250 7.3 Power Stroke (TRADED)
1995 Ford F-250 5.9 Cummins (TRADED)
1997 Ford F-250 HD 7.3 Power Stroke (SOLD but TRADED BACK)
1997 Ford F-350 7.3 Power Stroke (SOLD)
HondaTypeRk20 is offline
post #2 of 5 (permalink) Old 10-19-2011, 01:15 AM
Re: Hard Brake Pedal
that is your vacume pump, there easy to replace, but something about leaving the bolts in the pump when you put the new wheel on...guess you cant put them in after with the wheel on
95 f250 ECLB,silver/purple 199k FFD 350/200s, arps, comp 910 shimmed, BTS ZF delete, glowshift EGT,Boost,trans temp,6" aussies,6637, 6.oh IC,dual sd elec fuel. irate T4, S475/96,136k 97 motor. Twin termies
Plans: twin turbs, crowers and fresh rebuild.
rideracelivemx7 is offline
post #3 of 5 (permalink) Old 10-19-2011, 03:29 AM
Patrick Feeley's Avatar
Most likely the vacuum pump as mentioned. You can get the pump off the engine without removing the pulley by completely removing the bolts that will come off and backing off the one that won't. When you go to put the new one on, you will need to put the one bolt through the correct mounting bolt hole BEFORE putting the pulley on the new pump. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #4 of 5 (permalink) Old 10-20-2011, 11:21 PM Thread Starter
THANK YOU BOTH!!!
I was pretty sure it was the vaccum pump, but I just wanted a second opinion. Lol.
post #5 of 5 (permalink) Old 10-25-2011, 05:48 AM
Cantankerous Old Redneck
Old OutLaw's Avatar
and be sure to adjust your REAR brakes once inna while, they tend to not adjust themselves.....
'97 Centurion. F350 4x4 CCLB
Full Force 180cc Stage I's, D66, SRP-1.1, ARP, Banks IC, DIY E-Fuel, EBPV Del & Gut'd Ped., BD Brake., SD IDM, HPX, BstFoolr, 4" DP - 4" exh,
6.0 Fan, 180 T-Stat, DIY Don.105006 AF, CCV Mod, BTS, 3/8" cooling lines, Tru-Cool Max, PML, Bumper Mod, Gauges, Fluidampr, Mellings LPOP.....
Tuned by "The WildMan".....
Old OutLaw is offline
