possible oil leak culprit - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 10-18-2011, 10:58 PM Thread Starter
So with the turbo off I was cleaning the valley and took the cross over oil line off, i noticed it was wet around the head and took the fitting off and found this.
this is the drivers side
this is the passenger side
O-ring looks in much better shape. Oil is on the drivers side of the block, not much in the valley. Oil cooler is dry in the back so Im thinking this little o-ring could be the problem?
f250towrig is offline
post #2 of 14 (permalink) Old 10-19-2011, 02:51 AM
Re: possible oil leak culprit
Yup they can leak and is most likely the source of oil...
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10s 37Ē Toyo R/Ts intake, FFD 205/30s, DP 4Ē exhaust DIY E-fuel, ZF-5 now
lights: VisionX & HID projectors in headlights.
JCart is offline
post #3 of 14 (permalink) Old 10-19-2011, 04:15 AM
Drive it like ya stole it
geargrabbin97's Avatar
Those O-rings aren't just any old o-rings, they need to hold up to 3000+psi at like 450degrees. Go to you local parts store and ask for high temp o-rings, they'll be much stiffer/beefier.
97 F250 CCSB: 238/100s, 38r w/1.15 housing, SD conversion, 5" exhaust, Stealth pumps, e-fuel, 910 springs, pushrods, headstuds, intercooled, kevlar/ceramic clutch, tuned by Matt, gauges, 4" lift on 37s. D60 and ZF6 next on the list.
97 F250 ECSB: 3" downpipe, chip tunes by Jody, gauges stock height on 35s. SOLD
geargrabbin97 is offline
post #4 of 14 (permalink) Old 10-19-2011, 04:36 PM
You can buy those o-rings from ford, I think they are about 2 or 3 bucks a pop. Or you can order them from Guzzle
-John-
1996 F-250 Ext Cab Long Bed 4x4 w/ a few mods
jmsmith76 is offline
post #5 of 14 (permalink) Old 10-19-2011, 04:57 PM Thread Starter
we have an interstate ford dealer by me, only deal with diesel stuff, they say there orange though?
post #6 of 14 (permalink) Old 10-19-2011, 05:22 PM
yeah, pink...orange...doesn't matter, you'll be able to tell the difference in how the feel from a normal oring. these ones are not nearly as elastic, feel a whole lot stiffer.
post #7 of 14 (permalink) Old 10-19-2011, 05:37 PM
The ones from ford are orange, the ones from Guzzle are black
-John-
post #8 of 14 (permalink) Old 10-21-2011, 06:37 PM Thread Starter
So I out new rings on and it was like a new truck, but it started the poor idle again and sure enough the drivers side o ring was torn. I lubed the hell out of it when I put it in but it looks like it shaved the o ring when it got tightened down. I see or feel no burrs in the hole, any ideas?
post #9 of 14 (permalink) Old 10-21-2011, 07:59 PM
What did you torque it to? I believe the torque spec is 16-18 lbs-ft for those plugs...
-John-
post #10 of 14 (permalink) Old 10-21-2011, 08:40 PM Thread Starter
Hmm, I definitely over tightned it, did not know there was a specify torque for those. Thanks!
