truck missing and then dies - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-17-2011, 09:44 PM Thread Starter
i have a 95 and the other day i noticed my truck would start missing going down the road and lose all power would barely pull itself. then the next day it done it again and sounded like i keep losing a cylinder every so many miles till it finally just died and wont crank back. any suggestions of what could be wrong? it turns over but wond run.
dieselsmoke08 is offline
post #2 of 5 (permalink) Old 10-18-2011, 01:00 AM
rolsmojave3's Avatar
Re: truck missing and then dies
Lot of possibilities here. Is there fuel in the fuel bowl? Enough oil? Open the oil cap and see if it smells like burnt electrical.
97' F-350 7.3 5 speed, 160cc Rosewoods, 315/75r16s 16x10 MT fakelocks
96' F-350 7.5 5 speed, cali truck, 315/75r16s on Alcoas
02 Ranger FX4
79 "F350" mud truck, 18.5/44-16.5s
rolsmojave3 is offline
post #3 of 5 (permalink) Old 10-18-2011, 01:06 AM
More basics:
* Is the HPOP reservoir full?
* Does the WTS light come on?
* Do you get white smoke?
* Does the tach move when you crank it?
madpogue is offline
post #4 of 5 (permalink) Old 10-19-2011, 09:40 PM Thread Starter
I haven't checked it sense it happened bc its been rainin here but it didn't white smoke at all and before it died it would still gain rpms but not all cylinders where hittin the n eventually it lost so much power it would barely pull its self and died but no lights came on and no white smoke.
post #5 of 5 (permalink) Old 10-20-2011, 06:47 AM
No WTS light --> check fuse #22 under the hood. If it's blown, do NOT just replace it right away. Disconnect the fuel bowl heater first.
madpogue is offline
