IPR - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-17-2011, 07:17 PM Thread Starter
IPR
I was wondering if anyone know how to test I Ipr when it is removed from the truck. It's a 95 stroker that's been down for a while. I heard you can run twelve volts to it and should hear a click. I tried this and didn't hear a click but I don't know how trustworthy this info is. Thanks in advance.
-dustin
PS1995 is offline
post #2 of 5 (permalink) Old 10-18-2011, 12:08 AM
blageurt's Avatar
Re: IPR
I'm not too sure on that one...... but if it was in the truck you could check the Duty cycle and HPOP pressures with a good scanner..since it is out you might want to replace it or rebuild it however.....
95 E350 Cargo, E4OD , B/M aluminium Pan / 2 HD Trans coolers , Dana 60FF 3:55 , 140 V idm , Autometer guages , TDEO Dp flashed 60 Tow , EBPV delete , BB shim , cat sleeps with the fishes, Timbren SES, stage 1's coming soon
blageurt is offline
post #3 of 5 (permalink) Old 10-18-2011, 02:22 AM Thread Starter
Re: IPR
Ok I checked the pressure and it wouldn't even register but I'm un sure if it's the Ipr or the pump itself
PS1995 is offline
post #4 of 5 (permalink) Old 10-18-2011, 02:26 AM
Patrick Feeley's Avatar
Re: IPR
Have you checked to see if the IPR coil is open? In most cases it's not the pump (they are pretty reliable). Cheers!
Patrick Feeley is offline
post #5 of 5 (permalink) Old 10-19-2011, 02:39 AM
blageurt's Avatar
Re: IPR
How did you test the pressure ? Mechanically with a guage or electronically with scanner ? Maybe you have a toasted injector o-ring ( or a few ) or other leaks in the HPOP system or you have air in it ?
blageurt is offline
