Someone help me out here - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-17-2011, 03:30 AM Thread Starter
Can someone please explain to me what the exaust back pressure sensor does. the tube that comes off my manifold up to the sensor is broke but i havent noticed any change in anything so im jw what its funtion is.
Monstergamache is offline
post #2 of 5 (permalink) Old 10-17-2011, 08:11 PM
Patrick Feeley's Avatar
Re: Someone help me out here
It tells the truck's computer (PCM) what the exhaust back pressure is so that it can control the operation of the Exhaust Back Pressure Valve (EBPV, the big elctrically controlled, hydraulically actuated butterfly valve on the exhaust exit side of the turbo). The tube runs about $12 or so. You should have a nice exhaust leak from the tube, unless yours happens to be clogged with soot. Cheers!
Patrick Feeley is offline
post #3 of 5 (permalink) Old 10-17-2011, 11:38 PM Thread Starter
I knew it! Thanks man the truck hasnt seemed like its spooling corectly and it isnt as loud as it should be with a straight pipe so i think that stupid butterfly valve isnt opening all the way. it wont hurt anything if i just remove the butterfly and block that port on the manifold where the tube goes will it. Yea i do have a nice exaust leak from it its aggravating i hate that ticking noise.
post #4 of 5 (permalink) Old 10-18-2011, 12:27 AM
You should be OK doing that. Just leave the sensor hooked up, disconnect the EBPV actuator at the weatherpack connector at the base of the turbo on the driver's side so it doesn't cycle anymore. Cheers!
post #5 of 5 (permalink) Old 10-19-2011, 04:18 AM
Drive it like ya stole it
geargrabbin97's Avatar
There are all sorts of write ups on removing the EBPV if you're looking to free up your exhaust flow.
97 F250 CCSB: 238/100s, 38r w/1.15 housing, SD conversion, 5" exhaust, Stealth pumps, e-fuel, 910 springs, pushrods, headstuds, intercooled, kevlar/ceramic clutch, tuned by Matt, gauges, 4" lift on 37s. D60 and ZF6 next on the list.
97 F250 ECSB: 3" downpipe, chip tunes by Jody, gauges stock height on 35s. SOLD
geargrabbin97 is offline
