Pedal Assembly - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 10-15-2011, 12:50 AM Thread Starter
Pedal Assembly
I need a pedal assembly for my 94 F350 clutch,brake,acclerator where can i order one and if yall can help me out with a part number thanks.
03F250 6.0 is offline
post #2 of 12 (permalink) Old 10-15-2011, 01:09 AM
Re: Pedal Assembly
Check out here https://powerstrokenation.com/forums/...ad.php?t=27529
Should be listed in there (alphabetically) and is found in the Tech library 94-97 up top.
In terms of getting the parts I'd check out your local wreckers for the best prices, is this for a 7.3 litre powerstroke equipped truck?
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10s 37” Toyo R/Ts intake, FFD 205/30s, DP 4” exhaust DIY E-fuel, ZF-5 now
lights: VisionX & HID projectors in headlights.
JCart is offline
post #3 of 12 (permalink) Old 10-15-2011, 01:49 AM
Re: Pedal Assembly
Clutch and brake pedals come as an assembly. Go-pedal is just a big volume control, and NOT cheap. Why do you need all three?
madpogue is offline
post #4 of 12 (permalink) Old 10-15-2011, 07:10 AM Thread Starter
Re: Pedal Assembly
ok no i taught they all came together, the whole assembly is completely worn out thats why iam in need of replacing them, and yes it is equipped with the 7.3
post #5 of 12 (permalink) Old 10-15-2011, 11:40 AM
Re: Pedal Assembly
Tear it apart and rebuild it. New bushings and Heim joint mod.
97F250, EC LB 4x4 7.3 5sp 3:55,Donaldson Intake, Running W75/12.5/12.5 as of 2/20/12
Mudbrother is offline
post #6 of 12 (permalink) Old 10-15-2011, 07:45 PM
BrokeAss
Re: Pedal Assembly
What he said.
LMC has all the parts you will need to replace. The only expensive part is the assembly itself, and if you are doing this repair before it is too bad then you won't need that anyway.
Russo2 is offline
post #7 of 12 (permalink) Old 10-16-2011, 03:31 AM
Re: Pedal Assembly
Yes you can get a rebuild bushing kit for the peddle assembly from ford and should be listed in the above parts list.
jrc
JCart is offline
post #8 of 12 (permalink) Old 10-16-2011, 06:12 AM Thread Starter
Re: Pedal Assembly
Ok thanks guys the pedal assembly runs $210 so repairing cant be as much I think
post #9 of 12 (permalink) Old 10-16-2011, 08:51 PM
Re: Pedal Assembly
Yes it's easy to replace the bushings in the peddle box. Just rebuilt mine earlier this summer (had the kit for ages so don't have P/N sorry). Also while you have it apart get one of these
7/16" drill bit stop and put it on the end of the clutch peddle assembly to hold the clutch rod (that connects to master cylinder). You might have to trim the retainer tabs on the black nylon bushing to give clearance for the bit stop...works awesome.
jrc
JCart is offline
post #10 of 12 (permalink) Old 10-17-2011, 12:53 AM
BrokeAss
Re: Pedal Assembly
I would do the heim joint over what jrc said, but to each his own.
Russo2 is offline
