Replaced speed sensor, having same problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 10-12-2011, 02:05 AM Thread Starter
I was showing a speed sensor code in my 95, truck shifting into neutral while driving, speedo jumping at around 60 and hard shifting, overdrive light blinking on shifter lever. So I replaced it with a motorcraft one and I'm still having same issue, has anyone had the same issue and provide some insight
95 F250 4x4 Ext Cab, 6637 Mod
RobCassaday is offline
post #2 of 6 (permalink) Old 10-12-2011, 05:08 AM
Re: Replaced speed sensor, having same problem
Tone ring (the ring of "teeth" that interacts with the sensor) inside the diff?
madpogue is offline
post #3 of 6 (permalink) Old 10-12-2011, 02:14 PM
Cratos's Avatar
sounds more like the trans. if it is going to neutral
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #4 of 6 (permalink) Old 10-12-2011, 02:38 PM
Just speculating, but it's probably going out of gear as a response to the flaky speed signal. If the speedo function were normal, then that would isolate the problem to the tranny. But the speedo and tranny issues* together suggest a continuing speed sense issue. IIRC, the notches on the tone ring can also get gummed up with stuff (I think it can get magnetized, and pick up metal shavings), and that would throw off the pulse signal to the VSS.
*(Where else can a bunch of grown men [mostly] write openly about "speedo and tranny issues" without blinking an eye?....)
madpogue is offline
post #5 of 6 (permalink) Old 10-12-2011, 09:27 PM Thread Starter
The problem is only happening intermitenly, today while driving no issues, yesterday I did replace an aftermarket one with a motorcraft part and the speedo problem has subsided
post #6 of 6 (permalink) Old 10-12-2011, 09:46 PM
Get a good scan tool and find the codes, only way to fix it right when the OD light is flashing.
02 f250
countryboyrob is offline
