Parkbrake control - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 10-11-2011, 12:39 PM Thread Starter
HILL631's Avatar
Parkbrake control
When operating the foot parking brake is it supposed to rachet when gradually applying it? Cheers.
1997 F 250 (Not quite finished restoration)
HILL631 is offline
post #2 of 21 (permalink) Old 10-11-2011, 02:16 PM
Re: Parkbrake control
Mine doesn't
gsxr1216 is offline
post #3 of 21 (permalink) Old 10-11-2011, 03:50 PM
I have no idea because I just mash it really hard whenever I put it on. I'll try to remember to apply it slow and see what happens. I know my old Jeep would ratchet, but that was a hand brake.
97 F-250 ECLB ZF5 7.3 4x4, 6637 Filter, MBRP 3" to 4" with 5" tip, HPO xover pipe, shimmed FPR, Boost and Pyro Gauges, PHP chip with stock, 60 hp, 80 hp, 140 hp, high idle, and no start
iluv83vettes is offline
post #4 of 21 (permalink) Old 10-11-2011, 06:25 PM
No, you don't hear any ratcheting as you press the pedal.
madpogue is offline
post #5 of 21 (permalink) Old 10-12-2011, 12:22 AM
does the pedal move and engage the brake? If not you cables may be siezed. I am in process of replacing both of mine
bfoster is offline
post #6 of 21 (permalink) Old 10-13-2011, 02:01 PM Thread Starter
HILL631's Avatar
All cables have been replaced,all brake components replaced or rebuilt but park brake not releasing properly,put it down to crap aftermarket cables. Shop says that the foot control should rachet but l tried another F250 and everyone here says it does not so l going with that. What cables are the best besides genuine? It seems the genuine are not available anymore
HILL631 is offline
post #7 of 21 (permalink) Old 10-13-2011, 05:40 PM
I just replaced mine yesterday with orielly cables. Make sure they are not in a bind.
bfoster is offline
post #8 of 21 (permalink) Old 10-13-2011, 08:43 PM
Patrick Feeley's Avatar
I didn't have good luck with aftermarket cables. The housing covers would split and eventually let water, etc in and cause corrosion with binding. I went back to the factory Ford cables (which were actually about the same price online) and had no more problems. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #9 of 21 (permalink) Old 10-13-2011, 09:47 PM
STILL LEARNING
Bradbilt's Avatar
Dont feel bad. My 97 has all new FORD cables from the pedal to drums and all new brakes. My E-brake pedal goes right to the floor and I can push the truck by hand
Bradbilt is offline
post #10 of 21 (permalink) Old 10-13-2011, 11:53 PM Thread Starter
HILL631's Avatar
Where are the genuine Ford cables available from and part numbers? Cheers.
HILL631 is offline
