Corrosion in bottom of fuel filter housing - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 10-08-2011, 06:03 PM Thread Starter
So i pulled the filter housing to clean it since i found about 1/2" of junk in the bottom. The bottom of the housing had deep corrosion in the bottom. has anyone else had this problem? ive already spoke with "Kreem", they said that there kit that works on motorcycle gas tanks would work fine with diesel fuel. i think im going to pour a layer in the bottom and try it.
I do run on B99 fuel so im already rebuilding the housing seals and the fuel pressure regulator. the screen on the regulator was clogged and the hoses to the housing were soft so im replacing those also was gates greenshield hose (bio friendly). i also found the fuel heater loose. i think im going to delete it since miami gets so cold. any input?
Glenn
*1997 Ford F350 CC LB Dually-Tow Vehicle
7.3 Powerstroke-open downpipe
*1998 Ford Expedition
460BB, 24" lift, 44" tires, Dana 60 axles
*1995 Ford Mustang Cobra
460BB Pro Street Car
*1993 Ford F150 Lightning
stock (daily driver)
*New Project* 95 F350 7.3 CC LB on 28L 26 tires, 5 Ton Rockwell Axles, 40" Lift...
xcessivebronco is offline
post #2 of 2 (permalink) Old 10-08-2011, 06:05 PM
95powersmoker's Avatar
Re: Corrosion in bottom of fuel filter housing
I think I would just replace it with a used filter housing...
James
2000 F350 CCLB 4x4 auto, 250/200's from PIS, No Limit tunes, Isspro gauges, 4" exhaust and intake.
95powersmoker is offline
