What shuts off the PSD? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 20 (permalink) Old 10-07-2011, 07:19 PM Thread Starter
Local Machine Gun Builder
Kickin Y2K's Avatar
When you turn your ignition switch to the 'off' position, what happens to kill the engine? Does it kill power to the IDM, does it cause the IPR to dump all the pressure so the injectors can't fire?
Kickin Y2K is offline
post #2 of 20 (permalink) Old 10-07-2011, 07:27 PM
psdguy97
psdguy08's Avatar
Re: What shuts off the PSD?
I'd like to know too.
95 F-250 ECLB
6637 air intake, 3 inch dp to 4 inch exhaust, EBPV delete, ccv mod, glowshift gauges ( fuel pressure, boost, trans temp, pyrometer ) Dp tuner ( no start, stock, 80hp econo, 60hp tow)
Cobra 29 classic w/nightwatch, Wilson 1000 magnet mount, weather guard backrack, code 3 lightbar.
psdguy08 is offline
post #3 of 20 (permalink) Old 10-07-2011, 07:32 PM
TRUBBS's Avatar
Never thought about it either, wouldn't mind knowing either
TRUBBS is offline
post #4 of 20 (permalink) Old 10-07-2011, 08:21 PM
fordtough82's Avatar
i would imagine it kills power to the idm thus killing power to the injectors
97 f-250 4x4 psd, diy intake 6 pos chip fpr shim 3" mbrp dp into 5" dual stacks 4" lift on 35" mud terrains
DRC Performance
drcperformance.net
fordtough82 is offline
post #5 of 20 (permalink) Old 10-07-2011, 09:01 PM
Patrick Feeley's Avatar
It'll kill power to anything that's powered by the "Hot in Run" power. I guess I'll have to look it up when I get home (probably portions of the PCM as well as the IDM). Cheers!
Patrick Feeley is offline
post #6 of 20 (permalink) Old 10-08-2011, 05:48 PM Thread Starter
Kickin Y2K's Avatar
I'm glad I'm not the only one who doesn't know what exactly happens. Would be interesting to know!
post #7 of 20 (permalink) Old 10-13-2011, 03:55 AM
Drive it like ya stole it
geargrabbin97's Avatar
So then the question becomes, is it possible for a PSD to run away? I guess not?
97 F250 CCSB: 238/100s, 38r w/1.15 housing, SD conversion, 5" exhaust, Stealth pumps, e-fuel, 910 springs, pushrods, headstuds, intercooled, kevlar/ceramic clutch, tuned by Matt, gauges, 4" lift on 37s. D60 and ZF6 next on the list.
97 F250 ECSB: 3" downpipe, chip tunes by Jody, gauges stock height on 35s. SOLD
geargrabbin97 is offline
post #8 of 20 (permalink) Old 10-13-2011, 04:00 AM
Do you smell something?
Wackerjr's Avatar
You bet your ass it can run away....injectors don't need to be firing to burn oil.... (remember no spark, combustion ignition)
This has been discussed in length about banks dragster they have no air shutoffs, they think you kill the ignition it turns off on an electronic engine....
FYI the key off turns off the pcm power relay, which in turn kills everything else. turn your key on and listen real close you can usually hear the glow plug relay, and pcm power...
Wackerjr is offline
post #9 of 20 (permalink) Old 10-13-2011, 04:36 AM
bring the chain
kyle43335's Avatar
Key shuts off the pcm,idm relays shuting them down. Then as someone mentioned the 12 volt power source is killed by default dumping icp. But by the time this happens, the engine is already shut down.
kyle43335 is offline
post #10 of 20 (permalink) Old 10-14-2011, 12:56 AM
Yeah I guess not, for some reason I was thinking only mechanical injection could run away...silly me :p
