Engine gone or just minor issues? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-25-2011, 12:16 AM Thread Starter
ongoingshow's Avatar
Hello
We've got a 97 F350 with about 320000kms on it and we now have an issue which might be a shot motor but maybe not. When it's idling it sounds really rough (like it's running on a few too little cylinders) and when you open the oil fill cap its blowing out of there quite a bit! When in park, if you put the petal to the floor it slowly climbs up to about 2500rpm but it just can't get over that mark. Driving down the road you have no power whatsoever, empty it can do about 70km/hr but that's it. One guy was thinking dirty oil pressure sensor was the reason for lack of power and rough idle but another guy says since it's blowing such pressure out of the filler neck then it's more than likely the engines gone. Any ideas?
97 F250 Stick, Dana 60 Front, Rear 4 Link Air, Dual Terminator Setup, Beans Dual Fuel, Regulated Return, 6pos Chip by Beans, 300cc Injectors, Modified H2E, Studs, Valve Springs, 6oh Intercooler, DD SBC, Short Shift from Mid-West
78 F150 Lifted, Lockers, Rubber, Overdrive Tranny
11 Ecoboost AFe, Edge
ongoingshow is offline
post #2 of 7 (permalink) Old 05-25-2011, 05:44 AM
biggreen96's Avatar
Re: Engine gone or just minor issues?
with that much blow by id say your engine is dead.
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
biggreen96 is offline
post #3 of 7 (permalink) Old 05-25-2011, 02:43 PM
Cratos's Avatar
have you checked your fuel and oil pressure? with a manual gauge.
Blue 2012 XLT SCLB 4X4 , 38,550 miles, 3:55's & 18's Camper and Tow packages. Edge insight, Airlift Wireless compressor & Air Bag set-up, Dieslesite filter.
Cratos is offline
post #4 of 7 (permalink) Old 05-25-2011, 05:37 PM
Compression test?
madpogue is offline
post #5 of 7 (permalink) Old 05-25-2011, 06:53 PM Thread Starter
No, we haven't done any tests yet. Just observations so far. It seems kind of strange that the engine would be gone because it worked fine one day and then we start it up a couple days later and all of a sudden it's like this.
I suppose we'll put on our surgical gloves and start doing some tests then...
post #6 of 7 (permalink) Old 05-25-2011, 10:38 PM
blue99sd's Avatar
Have someone scan the motor, sounds like under cover harness or even a bad idm. Just done one on a 97.
99 PSD dually
4" lift 35' tire
4" exhaust to 6" Aussie's
K&n air filter
cc mod
Beans stage II 120hp injectors
Beans D66 turbo
ITP regulated return
updated ecm (2000 model)
reburned TS chip- 25,high idle,60,100,120,140hp
Dyno #'s 360hp and 965 ft lbs trq
blue99sd is offline
post #7 of 7 (permalink) Old 06-03-2011, 07:30 PM
International Shakes IT!
97F-250HD4x4's Avatar
Bad idm. My truck was doing the same thing changed the idm fixed it.
1979 F-150 rclb 4x4 4 speed 460
1995 F-150 rclb 4x4 5 speed 5.0
1997 F-250 scsb 4x4 5 speed 3in down pipe,4in exhaust, ts 6 pos chip, 100% nozzles, dana 60 front.
1997 F-350 cclb auto (for now) 4x4 stage 2 injectors
2001 F-250 ccsb auto 4x4
2006 F-150 rclb auto 4x4
97F-250HD4x4 is offline
